yea still a layer left on. Needs a good wash down, just hot water will not take it all off
Well as luck would have it, I broke the hard line for the washer tank. I may have to get a new one, or I think the 1/4" poly line that we have at work may be the same size. Grab a quick connect union at work as well and all should be good
Sent while drinkin' a cold one...
Let's see.... Today, I went to Line-X and got the bed sprayed. Then I installed my Fold-a-Cover tonneau. Then installed my GM led cargo bed lights.
Tomorrow I'm going to change the oil - only have about 1200 miles, but like to get rid of the break-in junk. Plus Advanced Auto Parts has a BOGO on Mobil 1 Super Synthetic - getting 10 quarts for $37 w/ tax. Will pick it up at the store tomorrow.
Just rammed into a girl leaving walmart truck was not stopping at all and of course the light was red so I bumped her.. truck took no damage lightbar saved the day again. Busted two lights but they still work lol. Didn't get in trouble either because they didn't want cops involved even though i dented their blazer and busted the tail light.
Sent from the toilet
You faired better than ironman tonight
Ryan
16 of them are in Indy. Took my 4 yr old to see em. Fun time
I am also a proud new owner of 2 copo camaros
Ryan
Monster Jam is in Little Rock also today. Grand son asked to go but he waited until today to ask and I did not want to sit in the nose bleed section so I told him to ask before the day next year. :jester:
Monster jam was here recently
Edited by SarahsGMC
I believe monster jam was here this past week or last week at the Verizon center in Washington, D.C.
Went to the gym/home depot and out to dinner. Big 35mile day in the truck; loved every mile....just over 1500 now.
Sent from my DROID RAZR HD using Tapatalk
    • In the 6.6 gas thread, I added information in my fluid change thread about these gauges and temperatures. With very limited data, it so far looks like ~30 degrees difference between front and rear.
    • I know; crap pictures.   Anyway, as a finale of sorts to this thread, I had replaced both differential covers and since they had the capability of adding temperature probes, I did that. These are MaxTow analog/digital gauges with stepper motors. They'll flutter around like crazy for a moment and start at a nominal 100 degrees Fahrenheit.   I drove a 30-mile loop to the grocery store, averaging 70 MPH (as much as 80 to see if there was a quick spike in temperature. The air temperature is 102 (ambient ?). but the first pic is 7 miles into the trip. The second is getting back into the truck after leaving the store; differential temperatures dropped about three to four degrees in 15 minutes. The third pic in on the road to my house, about a mile away.   In that run, I saw a high of 150F on the rear differential, and 121F on the front. I'm sure a longer drive or towing will see higher than that, and when that happens, I can update the observations.
    • You don't want to become predictable now, do you? 😏
    • Fully warm, coolant temp >194, closed loop.   Run time can be anywhere from just reached operating temperature to having driven 30+ miles.   The O2 chart (which is a feature I just discovered after reading) for the bad idle seems to be "most" of the time. For the little time I've been watching it (scanning and driving! watchout!) I can't seem to isolate any cause or condition yet.   It definitely idles rougher sometimes than others and so far what I've seen is the rougher idles are always rich. But not enough to set a CEL.   In other news I replaced the starter solenoid. Everything on this truck is such a PITA. Starter "snout" is mangled up with the torque converter inspection cover which is tangled up with hard cooling lines and the driveshaft. But I got 'er done without too much swearing...I just go into everything now knowing it's going to be a frustrating mess.   The starter solenoid replacement kicks off the next round of work: AC, injector rebuild, cat, exhaust. I'm just going to do it all. But first:   I don't know what my fuel pressures are. I can't definitively say the issue is the injector without first verifying fuel pressures and any leakdown. I "rented" a test kit ($199.99 at O'Really's ...intentional misspelling). They don't "rent" tools anymore, they charge you for the tool and then you return it when you're done. No joke. It is listed as a rental on the receipt but the guy told me there's no difference between renting and buying  now, you just return it when you're done and they refund the credit card. Mmmkay, whatever.   I will rule out fuel pressure issues (too much), and any leaking (that's how I'll know the problem is inside the intake). I think someone said the return line could be plugged or not flowing and that could cause high fuel pressure (and too much fuel being pushed through injectors). I'll cross that bridge if I get high readings.   As of now I'm ready to tear off the intake cover, extract the injector, and have it sent off to be rebuilt just so I can rule that out.
