Not so much worried about issues is I just want something new. The 2014s have had some teething issues but I'm sure by this time next year when I buy they'll be sorted out. No reason to hang on to old stuff when I can buy new and better.
They look cool but I won't buy one I'd have to spend a ton to delete all the nonsense on it and I'd rather not have a truck that will dent if you look at it long enough
sent from my truck in a field
Helped the future sister in law move, 3 loads in mine and 3 in a Ford and all done, thankfully the move was about 12 blocks so didn't take too long
Sent with Tapatalk powered by Droid
Why I hate winter (salt)
Ryan
Boo hoo
My sle badges are peeling off my cab due to the cold.. fml
Edited by SarahsGMC
Its not due to cold. My truck had them peel when it was 8 years old too. Went to LMC and bought new ones
Lemme see.... since the 05 is being replaced it has decided to implode. Today I did waterpump number 5 ( went $400 OEM gm this time), this is its third encoder motor assembly ( again a new OEM gm one), and the front driveshaft seal on the t case started puking.... and the seal is a misery... its a 2 piece rotating thing that presses into the case as well as on the shaft... I gave up and booked it in a shop tomorrow for it. Getting the old abortion out is one thing but not screwing up the new one going back in is another... Oh well.
And I started my modding of my new one. First off was toss the ugly step bars off and yank the front licence plate bracket. Next will be pulling off most of the decals on it, tint, 3m, mudflaps, exhaust and a tune. All with 20 miles on the odometer lol.
Sent from my SGH-I747M using Tapatalk
Edited by Badass69
Hell no lol.
I hauled the old 05 into town to let a shop swap the seal.... and in its last hurrah it tried to fall off the trailer. No 4wd and its snowing so stuff is slippery. Touch the throttle... and I mean just off idle and it spins, pulls sideways and almost falls off the ramp... Thankfully I have a winch so sucked it back on the trailer and borrowed a floor jack to lift the back of the truck and center it on the deck again. Them off it came. My spare tire carrier on the trailer us getting cut off too... its always in the way as it sticks up beside the deck. It broke the front of my inner fender but didn't wreck the valence thankfully.
Edited by Badass69
Changed front brake calipers and an oil change on my apprentices Ram.
Got a new hat today (Chevrolet )
Ryan
You bought a new hat that is torn? Please tell me you don't also buy pre-ripped jeans. :lol:
Was supposed to drive up to Midland for a customer visit and arrive early to take the safety training. TPS in the truck took a crap and left me driving 25 miles back home in limp mode with a max speed of 40 and sloooooooow acceleration. Dealer can't provide a loaner/rental for same-day repairs so I had to get a rental through work to drive up and do the job. Truck is done but I didn't get back in town in time to get it so tomorrow that will be the first thing I do. Be curious to see if the new programming that goes with the new TPS makes the truck drive any better. Not that it matters since I'll load the tune in as soon as I'm back home.
Ya, i didnt realize it was ripped when i bought it. Thats they style? Comfortable hat though. Why is the pic sideways on my phone it looked fine in the post?
Pre-ripped jeans? Hell no. Skinny Jeans? Hell no. My jeans only get ripped while working (or on the inside of the garage door when I snag them grrrr)
    jaszr2
    jaszr2
  • Who's Online   6 Members, 0 Anonymous, 550 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
