I've put exactly 0 miles on it since the 1st of March. Can't wait to get this transmission in and stop driving this damn VW Rabbit lol
Sent while drinkin' a cold one...
I've put exactly 0 miles on it since the 1st of March. Can't wait to get this transmission in and stop driving this damn VW Rabbit lolSent while drinkin' a cold one...
Haha a rabbit.. That probably feels like it's decreasing your manliness
Got home from work and saw this...evy3e8ev.jpgsent from my truck in a field
You have to be glad that didn't happen while you were driving, or that center cap would have been long gone
I feel like it has. Need to bring it back with 12 mpg and a burnout haha
Decrease? It has eliminated haha
Ryan
Been contemplating on doing roll on bed liner from the rockers up the piece of tape halfway up the door, temporarily until I save enough to get a paint job and body work done. Thoughts? Or should I just keep it as is until I'm ready for body work and paint job? Have to redo rockers while steps are off. Didn't do a very good job on em last year
Got home from work and saw this...sent from my truck in a field
It did happen while I was driving because it was on there before I left
Redneck fab haha I'm welding brackets onto the back next weekend but here's my new lightbar
Well, ummm, scratch that last idea. Guess it's time for body work and paint job now!
Finally washed the truck for the first time in atleast a year haha and i changed the spark plugs an wires last week. No telling how long the old ones have been on. They looked horrible. She runs so much better thanks to something as simple as a spark plug change!
It did happen while I was driving because it was on there before I left Redneck fab haha I'm welding brackets onto the back next weekend but here's my new lightbar etetyju7.jpggyrysy9a.jpg sent from my truck in a field
Passenger side fog light is out there Sarah. Guess its time to upgrade to HID's in those too lol
It's badass I gotta make a new front end so being on this current bar is only temporary.
I got passed by a prius that was hitting triple digits
Gas pedal stuck??? Lol. Suprised the panels didn't fly off of it, since they are so cheap and flimsy
    RangerRick17
    RangerRick17
  • Who's Online   5 Members, 1 Anonymous, 557 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
