Not today but where I was last week!!! :jester:je7y9ypa.jpg
Not saying it will, I carry a plug kit in my truck after all... Just saying I won't leave a tire like that long term and it may void your tire warranty.
It might but tire warranties are almost worthless. The companies are horrible to deal with and the replacement program/credit is prorated usually so you end up barely getting anything.
I got my Coopers there but I'll never go back to the one in Jackson. They're such hacks. Damaged a wheel and used steel wheel weights instead of ones meant for aluminum wheels. These tires will last till next year though then it's not gonna be my problem anymore with any luck.
I used Direct and had my local garage put the tires on. I was impressed with how new the tires were, according to sidewall 2 months old when I got them. I have noticed if they sit too long they can be harder to balance.
I may stop at the Denton area DCT next time I'm in Dallas to have them siped, but I'll make sure to see if I can find any dirt on that location before I do. Thanks for the heads up.
Scratch that, there's one in Carrollton.
Edited by kstruckcountry
As for the plug the screw only went in maybe 3/8". It wasnt large. I believe the plug just sealed the hole. The tire wasn't leaking air.
Ryan
Edited by RyanbabZ71
What's so special about the 04 crew cabs compared to an 03 or 05- early 07 crew cab? Same body style but in 06 they changed the grille
Sent while drinkin' a cold one...
04 was the 1st year and were only a partial year run. Only 1500 crew 800 series with rear discs also
Edited by Chris
So 04 was first year run for crews? I always thought they started 1500 crews in 03 after the face lift
They had crews in the 90's though
Not in the silverado/Sierra 1500.
And CJ the 800 half ton crew came in 04. The Denali went crew in 05. Most the 800 half ton crews you see are 05-06
Yeah your right. All of the crew cab gmt800's I've seen are 05- early 07. May have never seen an 04 crew cab for sale
Yeah your right. All of the crew cab gmt800's I've seen are 05- early 07. May have never seen an 04 crew cab for sale Sent while drinkin' a cold one...
If it is all stock, it will have 16's, if the wheels are changed you can tell by rear discs
    ChristopherDobson
    ChristopherDobson
  • Who's Online   2 Members, 0 Anonymous, 1,164 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
