What the heck is with the sudden rise in E85 prices?
Ryan
Regular gas has skyrocketed too. Don't get it. Don't like it. :lol: E85 went up like thirty cents the last few days. Premium when up a bunch too.
May have to do with worldwide supplies and the stuff going on in eastern Europe. Probably go higher if something else happens(aka when the rest of Ukraine goes)
Worldwide supplies is BS. America hasn't been this energy independent in decades and most of the rest comes from Canada. But I'm sure that's the excuse. That and speculators getting rich off our backs.
Yeah, I never said it was a LEGIT reason. Europe wont touch Russia over Ukraine, as Crimea is a pretty big NG producer for them from what I understand.
Edited by SnakeEyes
Pulled the truck out of the garage so I could clean my floor, then pulled it back in. Exciting sunday here
e85 should have little change due to world effects as it is mainly made here
Ryan
Ryan
Doesn't matter. They raise it cause they can.
I know but it shouldn't. Nothing we can do about it
Ryan
The thing is ethanol is made using other fuels, mainly diesel.
If the government quit subsidizing the ethanol "industry", no one would be able to afford it.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   2 Members, 0 Anonymous, 1,207 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
