I'll be changing diff. fluids tomorrow and my tcase gasket. Screwed up on the last one, forgot to scrape off the old gasket. Costing me now. Also plan on flushing trans before winter but need a backup o ring for my mag hytec trans pan
Sent while in 'Murica...
I took an EcoBoost to the California Hot Rod Reunion
No expert, but I'm pretttyyy sure that's from the gears breaking in. At least, I hope it is
Fluid was also milky, not sure how water got in the front diff. Could explain why it's been quite noisy lately
Replaced the rear tailgate cover finally bought it like 2 yrs ago
Ryan
Got the 37s home! Really happy with the buy! They are massive! Filled up my whole truck bed!
Edited by GrapeSoda
Ryan
I really like the Stars and Stripes bowtie.
Edited by JaBradt85
Thanks it adds a little something to the plain bow tie
Ryan
Did you replace the cover because it had a nick on it? lol
And today I filled her up and took a drive up to Carefree/cavecreek with the family. We just drove around some back roads and enjoyed the scenery, while also hitting up some fun dirt trails.
Edited by white1500
Funny
No because the center against the tailgate didnt sit flush it was warped pretty bad.
Ryan
When you use your bed it does get wore out
One of many examples
Ryan
Not to worry old chap, that is normal. I like to drain the front and rear diff between 10,000-15,000 miles, same with the transfer case, then every 30,000 miles after that or sooner if needed (severe duty/water crossings) I will also do the tranny drain/fill or flush every 30,000 miles, coolant, power steering, and brake fluid every 50,000 miles (mostly because I will do 50,000 miles in about 10 years so age plays more into that. Never had a problem that way.
^^^ Yeah I do bout 20 - 25k a year so I normally do diff fluids, tcase and trans fluid once a year. Most of the time I'm working on something in between those times so I normally never make it the full 30k lol
Drove to the track for the races and after a 30 minute drive realized we forgot the key for the ramps. So we parked off road to angle the trailer right.
#NoRamp
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
