Yeah if I try to rev it it detects the rpm jump from idle and will start calculating. I wonder what I could do with a built lq9? Haha
Sent while in 'Murica...
My truck is just gonna be a cruising and dirt road road truck for now until i get it re geared and tuned! not a speed demon!
If I ever fix up the body on this truck and put in a new motor it would be a n/a lq9. If I wanted to boost I would go with LQ4. And I wish I could get a free blower, then I'd put one on there lol
@GrapeSoda you're gonna love it when you get it regeared. Pssssttt 4.88's [emoji6]
Thats exactly what I'm planning on spending my tax refund on :) !
Clayed all windows applied aqua pel and DP glass coating
Ryan
Renewed my registration and got a new style license plate. For $5 I figure I can keep changing it as often as new designs come out so if I ever leave the state I'll have a collection.
Discovered the source of noise on deceleration. My front inner brake pad on passenger side has gotten hung up somehow and is grinding into the rotor. Funny when I bought new tires and paid for the lifetime rotation, I was told they look for these kind of things as a "courtesy"...yup, they checked it and let it ride for me too. Oh well, it was about time for new front brakes anyway. Just means I will be working on both mine and the wife's Jeep this weekend.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,244 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
