Drum brakes are a a PITA!!!! Got the back brakes done! Glad he knew what he was doing!
We had to cut a hole in the rim to get a big ass pry bar in there to get it off. We spent a solid two hours struggling with getting one tire off then the drum took 30 minutes of pounding to get off.
Got a new Edelbrock carb on it as well thanks to my buddy, he gave it to me for free as well as some LT headers. Truck is one step closer to running ! Just got get front done and get three tires, and some fine tuning!
I thought this thread was about what we did to our trucks, not where we parked or ate?
My thread my rules Edited by SarahsGMC
Took my 02 out for most of the day yesterday. Ran her down the highway and I don't remember having all those vibrations coming from it. Around 85 the truck felt like it was gonna come apart. Something must be out of balance, I hope lol
Edited by rdnckhntr94
That comes from riding in that fancy new truck.
Oh no, it definitely shouldn't be there lol but it is definitely a lot nicer to drive than my 02 that's for sure haha
No ice. It was almost 60 yesterday lol. I think it has something to do with the steep gearing, tire size, and the front driveshaft. Think it is spinning too quickly because of the gears and tires are worn down to like 33's from 35's haha
Dad asked me to drive his 09 because he felt like trans was slipping. Drove it to go do some errands to see what he was talking about. Clearly transmissions have a thing for me because now his 6l80e is shot. 180k on it. Guessing that's the expected life out of the 6 speeds??
Gave it a wash after the nice salt storm (2" of snow) we had here
Ryan
Haven't had time to wash mine but I am REALLY liking that deep rumble from the Borla, I've been standing behind it and using the remote start to listen to the start up sound, really happy.
My stock exhaust with the 6.2 sounds nice. Wonder how a new exhaust would sound?
Ryan
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
