I moved my mom today
Sweet, with and without the truck.
only 3 each?
My snowblower is ready for tonight/tomorrow
Ryan
We have a son about to turn 2 so I definitely understand!
And I'm about to change the oil/filter with Castrol 5W-30 and the pf46e. It gives me more piece of mind this weekend when I'll add 300 miles or so as we go up north to constant freezing temps.
Can't wait to see it. Got a date night planned with the mrs tomorrow. Be nice to go out by ourselves for once. Terrible twos.......lol
Twin 2 year old boys.
Pretty much nothing scares me anymore.
6d1afc207308f84b1f7acb137beb09ef.jpgClean and happy
Wow, the size difference. Anyone seen a C/K and new Canyon or Colorado side by side?
Truck doesn't get driven much these days. Today I just ran out to grab a few things I forgot when I did some shopping on Wednesday. Of course tonight it was crazy since everyone is freaking out over the storm. Because a foot of snow justifies people panic shopping to buy enough stuff to last a month right?
Here are the 2015 GMC's side by side.
I meant a 90 1500 and a 15 Canyon, for instance.
In that pix though, looks like the canyon might be bigger than a 90.
Edited by SnakeEyes
It easily could be.
lol i know but the best I could do was get that pic since we could already see how a K2 compared to the 90's chassis.
Karnut, you get tried of the pretty blue truck give me a call I think I would take it off your hands!!!! :jester:
I tend to trade or sell my toy every two or three years, I was trying to own one of everything . After 40 years I think I'm din with that. This ones a keeper. It would cost to much to duplicate , it has everything done to it you could do to a truck, and cost to much to duplicate.
Changed my oil on Saturday and washed my truck yesterday. And then it decided to rain today.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 1,000 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
