That's right if anything goes bad trade it. Lol
Its a 5 year old truck now. He needs to trade.
If it goes like the last truck I have 4 more years
Ryan
At 9500ft in flagstaff:
2900m
And since my rear tires look like this, I'm glad there isn't snow down in the city!
Went to monster jam with my son. Great show, grave digger once again brought it to indy
Ryan
What are the trucks parked along the wall at the top left (left of the red trailer) and bottom right (above the Nationwide 4G LTE signs)? They look like street legal "show" trucks. Did they "race" those too?!?
Edited by sahls01gmc
They had a local 4x4 club out there. They had Pit passes and did a parade lap before it all started. They do it every yr
Ryan
Getting ready for a blizzard suppose to get 24-36" at my house.
Truly weird weather. In Kansas City, it's usually around 10 degrees everyday. Supposed to hit 62 today, and 70 on Wednesday.
Stay safe! Hopefully you have enough supplies that you won't have to venture out for a while.
Got gas & then drive downtown for an allergy shot. Also picked up a new tire pressure gauge since the old one only went to 50psi & now have a need to go up to 80psi on rear tires. No serious repairs planned for the truck this weekend but might just continue to detail interior.
Drove it to work then to the gym. Thinking about looking for a used decent mileage L33 to swap in.
If you can find an L33. They tend to be hard to find.
You would have better luck finding a decent mileage LQ9, and those arent easy to come by anymore
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,307 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
