Okay. Didn't think they were that rare though. I've had two trucks with them, and my brothers Sierra has one too.
More rare than the LQ9. The L33 was only in ext cab, 4wd trucks 2005-2007. And not all ext cab 4wd trucks got it
Wow, didn't know that. I'm getting a lot of listings on the two sites I've found them on. I guess if I do decide on one I'll have to identify them correctly.
And it may be called an L33, but you may in fact be getting a LM4. The LM4 is the aluminum 5.3 identical to its iron LM7 counterpart. The LM4 was in the Trailblazer, Rainier, Envoy, and SSR
Haven't done much other than get some gas for her. Been so busy with the weekly snow storms up here in NH i have probably 4 feet of snow in my yard right now.
I too am intrigued with the "laser wash".
Washed my truck and filled 'er up with petro. Nothing too exciting today.
Around here a "Laser Wash" is just a regular automatic car wash most are the brushless type. :jester:
So a fancy name for a touchless wash geesh lol
When I replaced my DRL bulbs a couple of weeks ago they both worked for a few days. Then late last week the driver side quit working again. So last night I finally got the initiative to take a look at what is going on. The bulb was popped out of it's socket. Plugged it back in, just haven't tested it yet since it was dark last night when I was working on it.
Fixed my fuel cap cable not being long enough to hang on the hanger!!! The end of the plastic had caught in a bed seam and it was just long enough to unscrew and then hit the bed just below the fuel door. It was a pain to hold it while getting fuel and since it is sunny and 65 degrees today thought that I would fix that little problem, before it drops to 10 degrees and we get some of that up north weather!!! :jester:
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
