Hahah I know I know, well you pay 60k and let me know how You feel about messing with a brand new truck
Oh and I ordered a downpipe today!
I'm trying to crawl out from under the mountain of debt. And my next debt will probably be an econobox and a house
Getting a new intermediate shaft and bearing for the Tahoe, just trying to decide between Dorman and borgeson for the shaft, wondering if the borgeson is worth the extra cash.
Ordered exhaust, tune and lift pump for my LML... Finally have enough courage to void the warranty!
I got my exhaust and put it on and put my steps on waiting on my lift to show up.
  • Like 3
Supposed to snow again here tonight, if I don't see any plows out putting down cancer juice I'll go play.
HAHA...Oh the cancer juice...
Post pics up when you get the lift on!
I actually got to roll down my window to show my ID at the gate to the base this morning....SO glad to have gotten my power window working again!!
It was getting really annoying to open the door and let all the heat out of the cab every morning.
Washed truck around noon @ 26°. 4 of 5 bays were being used.
Though by the time I got home, have only somewhat less ice/salt/winter crap on it.
#%$& winter!!!
Sprayed the salt off
4 bays only 1 open
9 degrees
Ryan
I know, right?
You have no room to talk. God damn RB
Went to Lowes and spent over $500 buying insulation and can lights, base board, and a exhaust fan that has blue tooth that plays music off your phone or iPod can't wait to install that bad boy. Checked the status and my lift kit will be delivered tomorrow.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   3 Members, 0 Anonymous, 1,252 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
