I finished the passenger side valve cover gasket today, a week or so after I did the other side. This side was a huge PITA due to less space towards the back due to the firewall, heater hoses, and dipsticks. It was generally a shitty job due to that, everything just takes longer than it should.
And I ended up ripping the pcv hose that runs from the valve cover to the throttle body so I had to stop everything and source one, then go pick it up. Luckily simple 3/8 fuel/pcv hose from O'Riley's did the trick.
The old hose was melted was melted onto the metal tip from the valve cover, very strange.
Next up is an oil change, hopefully by the middle of this upcoming week.
Mileage is at 232,700 as of this afternoon.
Passenger side
The drivers side was very clean on the inside compared to the other.
Drivers side
Screenshot from video showing which tools are needed
Edited by white1500
Passenger side
Drivers side
What oil do you use? Does your dipstick have a brown tint too? Mine did when I bought it, three rounds of Pennzoil platinum cleaned it off.
You could see the valve spring of my cars from the oil fill spot, they looked new on both cars when I sold them, after buying new, 7 years later using penzoil platinum for most of them.
I've been using Castrol GTX 10w30 and 5w30 for the past 2 years but prior to that it was mainly Valvoline.
These images are with the oil about to hit the 5k mile mark. And the dipstick is clean, it doesn't have any sort of tint or residue.
Sent from my SM-G360V using Tapatalk
A car I bought used ran conventional for after the 6 digit mark. I ran some synthetic for 2k miles and what came out looked like coffee. Might think about trying a round, I'd bet you'll be amazed how dirty that oil would be. Edited by SnakeEyes
That's how they blend now. They say it's for a perfect match, but I had a body guy tell me it's unecessary if a painter is worth his salt. That guy just sprayed about a foot around the damage on my car at the time and the paint match was perfect. Charged about a third to half of what the other shops wanted because of it. Said he was almost fired from a shop because the manager was getting upset over him not blending further out. Asked the manager to point out where He painted a car and the manager guessed the wrong spot, manager looked like a fool and then got really mad.
He said so many painter's just aren't good enough it's standard practice to paint several feet all around the damage. I'm sure $$$ has a lot to do with it also.
Kinda what I was thinking good to know that fender was scratched all to hell from working under the hood just means I have one less fender to replace
Sent from my SM-G925V using Tapatalk
No new campers to pull today...nor Friday, or Thursday...never gonna make it to a million.
Have had some bearings and seals replaced but engine and Trans is original.
IMO GM diesel is designed to go a million if you don't put extra power to it.
Edited by Chevor
Rear end all original or carrier and pinion bearings and seals replaced?
Rearend has had work down. And extra work at that do to GM tech over tightening and forgetting to tighten parts. Shop fixed a lot of that work free of charge. That guy doesn't touch this truck!
I Put a set of Bilstein 4600s on the front; I did the rears earlier. They feel nice.
Edited by Singer-Man
My brother's 2500HD barely crossed 200k. Now the body is rotting out, frame braces in the rear have rotted in half, hitch and spare fell off, doors leak like sieves, and now it sits dead due to an electronics failure - some magic box that controls the injectors. :banghead: Not to mention the 5 window regulators it's been through, the fire that nearly totaled it 4 years ago, and all the other failures that have already been fixed.
Million miles my ass!
:shakehead:
It's the pewter/copper colored one with the tarp over it, waaay in the background ...
That doesn't happen if you clean and keep paint on the frame.
    d.lowrey
    d.lowrey
  • Who's Online   3 Members, 0 Anonymous, 4,376 Guests (See full list)
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
    • I had a evap sol go bad a couple weeks ago. . I replaced it.  While watching live data at the time I saw I had some cylinder 1 misfires. No MIL but on live data I could see ~50 at startup and about 70 more after an hour a drive all on cyl 1.  I also noticed that the LTFT were -5% to -15% always.  And that bank 2 is always -3% richer than bank 1. Even across all driving modes, city, highway, etc it’s always 3% richer than bank 1. So I start with the misfire. Swapped coil, plug, and plug wires from 1 to 3. No follow. I got an Injector reseal kit, pulled the D/s injector rail, swapped #1 and #3 injectors, resealed them, reinstalled and retested.  The misfire followed to 3. So I ordered and replaced all 8 injectors, spark plugs, and plug wires. Also replaced the 1 time use fuel pipes under the intake manifold.  Injectors that were in the truck since new were  Part # 12668390.  I replaced them with # 12742701 Got from RockAuto. Pretty certain they’re genuine and the correct ones. I called a friend at a parts store who told me “the 12742701 were the correct superseded part # for the originals I was replacing”. So started truck after replacing all that and it’s running -15 - -30 LTFTs. I reset the fuel trims with GDS2 and drove it for a 60 miles trip each way. There have been no changes in the LTFTs.  I checked if the HPFP was leaking into the crankcase. I removed the pvc and watched the trims. No difference.  I checked the alcohol content and it was at 10%  I’m out of ideas here. Truck seems to run great. Just always rich on the fuel trims.  Anyone with any help or ideas would be greatly appreciated.  I ran an injector balance test just for the heck of it and it came back this. I’m confused.  I have gds2 and some other diag tools if anyone knows of anything I should test next.
    • Definitely needs to go back to the dealer.
