One extreme to the next out there in Cali!
My driveway this morning
That wet stuff is called WA-TER. [emoji38]
So the legend is true?
If I was gonna get a 6.2L, how many miles should I not go over if to buy one?
When I bought my '07 5.3L it had 102 when I bought it, never did use any oil at all.
That would be your decision to make. A truck with 80,000 miles may actually be in much better mechanical shape than one with 25,000 miles depending on how they were treated.
You are going to want to know how the truck was used and if it has been serviced regularly. Knowing that should make the decision easier when it comes time to buy.
Remember that the 09-13 6.2L Sierra & Silverado did not have AFM so nothing to worry about there. Those years are GM's best for the 6.2L truck engines. The new trucks all have AFM! GM should have not messed with the 6.2L truck engine, they were perfect without cylinders turning off and on.
Sent from my crappy iPhone 6
using Tapatalk
Move able parts work best if they keep moving.
Truck went in for a oil change in the dealer followed with some brake line recall and for a werid downshift feeling and then I had to show them where the zerk points on the tie rod was they didn't even no they were there... That's comforting
Sent from my SM-G900W8 using Tapatalk
Fogs and license plate lights are in... My reverse and cargo should be in later this week and hid kit going in tomorrow hopefully pretty exited...
Damn that is so true.....
I started parking the truck and taking the gas-sipping car to work to save gas/money/miles/etc..., but the truck just doesn't run right anymore. Need to stretch her legs out a bit at least once a week, and continue to fix the "little" things.
License plate lights not going in did I get the wrong stuff... Because I'm pushing hard and there not popping in b0b9de2d579872eec7efd781aa1de947.jpgdf1b33e1f10cac193f0b936bb0ba28b0.jpg9533109950d30b648fbb715198ce58a2.jpg
They didn't even light up and I threw the oem ones in to check but they both didn't light up... b97e30b242bcfe71983b362bd71b54da.jpg
Changed oil. Found out the trans was rebuilt 5 miles before I bought it!
When I bought it most of the fluids looked brand new. But, I wasnt sure so I just called the GMC dealer to get the odometer from whichever services.
They said all they had was some hoses, oil change and a transmission overhual. I confirmed it wasn't a service, it was a rebuild.
Its been about 10k miles since then(remember it was a once or twice a week thing until last month). Fluid looks and smells excellent, so I guess I can wait a while for that next flush
I'm going for coolant, PS, and brake flushes next month before vacation.
Ryan, got the same ones. Excuse my language, but they were a bitch to put in. I had to press REALLY hard. Worked fine in the end.
Yes there were a real pain in the ass.... And I had to call vled and they explained that sometimes the wires on the bottom move so I had to force them over then went under the truck and used both thumbs and pressed extremely hard and they went in and light up now... The fog lights look killer as well that I got from them but the passenger side one has me paranoid because I can't be sertain both clips clipped it was giving me a really hard time...
    • I know; crap pictures.   Anyway, as a finale of sorts to this thread, I had replaced both differential covers and since they had the capability of adding temperature probes, I did that. These are MaxTow analog/digital gauges with stepper motors. They'll flutter around like crazy for a moment and start at a nominal 100 degrees Fahrenheit.   I drove a 30-mile loop to the grocery store, averaging 70 MPH (as much as 80 to see if there was a quick spike in temperature. The air temperature is 102 (ambient ?). but the first pic is 7 miles into the trip. The second is getting back into the truck after leaving the store; differential temperatures dropped about three to four degrees in 15 minutes. The third pic in on the road to my house, about a mile away.   In that run, I saw a high of 150F on the rear differential, and 121F on the front. I'm sure a longer drive or towing will see higher than that, and when that happens, I can update the observations.
    • You don't want to become predictable now, do you? 😏
    • Fully warm, coolant temp >194, closed loop.   Run time can be anywhere from just reached operating temperature to having driven 30+ miles.   The O2 chart (which is a feature I just discovered after reading) for the bad idle seems to be "most" of the time. For the little time I've been watching it (scanning and driving! watchout!) I can't seem to isolate any cause or condition yet.   It definitely idles rougher sometimes than others and so far what I've seen is the rougher idles are always rich. But not enough to set a CEL.   In other news I replaced the starter solenoid. Everything on this truck is such a PITA. Starter "snout" is mangled up with the torque converter inspection cover which is tangled up with hard cooling lines and the driveshaft. But I got 'er done without too much swearing...I just go into everything now knowing it's going to be a frustrating mess.   The starter solenoid replacement kicks off the next round of work: AC, injector rebuild, cat, exhaust. I'm just going to do it all. But first:   I don't know what my fuel pressures are. I can't definitively say the issue is the injector without first verifying fuel pressures and any leakdown. I "rented" a test kit ($199.99 at O'Really's ...intentional misspelling). They don't "rent" tools anymore, they charge you for the tool and then you return it when you're done. No joke. It is listed as a rental on the receipt but the guy told me there's no difference between renting and buying  now, you just return it when you're done and they refund the credit card. Mmmkay, whatever.   I will rule out fuel pressure issues (too much), and any leaking (that's how I'll know the problem is inside the intake). I think someone said the return line could be plugged or not flowing and that could cause high fuel pressure (and too much fuel being pushed through injectors). I'll cross that bridge if I get high readings.   As of now I'm ready to tear off the intake cover, extract the injector, and have it sent off to be rebuilt just so I can rule that out.
    • What are the conditions of this rich idle? Warm or cold engine? Run time? Does every idle look like this or only sometimes?
