How many miles on that one Zach?
190,000
I made it go away temporarily 1-2000 miles ago, but it's permanently back now.
Ahh ok, I guess I've got some time to do the AFM delete before things begin self destructing. Mine just turned 77k miles today.
I've been told by several people that I'm lucky it lasted this long. Said they see this happen between 90,000 & 110,000 more regularly.
Thanks for the info. I guess I'd better start spending some money on this thing ... as if I haven't already. :sick:
My brother has an EFI Live setup he wants to sell me ... but damn it's expensive ...
That's one of the ones I'm looking at. Definitely not cheap, but one of the ones to use for a Blackbear tune. Edited by ZachM1
Arthritis and my spinal problems, combined with lack if a 5 inch deep 18mm socket has taken its toll. I just got one spring compressed but need the socket for the top nut Tomorrow morning I'm waving the white flag and taking it to the nearby tire shop to have them swap the spring to the new assembly(compress the other spring and remove that friggin nut.) I'll rebuild myself and have them decompress and reinstall the nut, take the assembky back home and finish myself.
Oh, and my home AC is fllipping out. Probably going to order a new home AC :(
Sent from my LG-D800 using Tapatalk
Yup my dads went out at 105k. Luckily we buy all our vehicles through this one dealership and they let him buy an extended warranty which covered half the cost of the repair
Maggy 22", 12589
14" magnaflow
I want something obnoxiously loud that sounds like freedom. Basically I want something that will scare women, children, the elderly, and animals lol
Edited by rdnckhntr94
  • Like 3
Those friggin strut springs on the 07 up Silverados are INSANE. The wire size is fatter than anything I've ever seen for a half ton, and the spring tension is enormous. I have a heavy duty (but chinese) spring compressor that bent trying to compress mine, and it didn't flinch 1mm! Nobody around any automotive shops had a press that would handle these. Had to go to the dealer with the strut assemblies, and have them install the 2 Bilsteins for $90.
I'd imagine this spring under tension would be like a small IED ...
Borla XR-1
Borla XR-1
Yup.
There were sportsmans on the bird. Its like 90-95% of open headers loud.
Edited by SnakeEyes
STACKS
I'm not into loud exhaust unless I'm romping on it. Surprises passengers better that way.
Edited by kstruckcountry
STACKS
Stack stacking stackers [emoji23]
I'm usually always romping on it anyways lol. I'm running my catalytic Y pipe with 3 feet of pipe right now so it's pretty close to stacks haha
    ChristopherDobson
    ChristopherDobson
  • Who's Online   2 Members, 0 Anonymous, 1,207 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
