I miss that area BADLY.
It's supposed to be 30 and snowing on Tuesday, so trying to get as many of them re-sealed before it hits! I love my pumpkin spice.....wish they still had some left. Hopefully there will be a new scent this coming fall.
Few wks ago bought a gallon on sale for $29 and got a 16oz free :)
I hate winter
Ryan
I hate winter
Ryan
Total side note...
Ryan, do you off hand know the part number for your sill protectors? Not the still plate but the protector that goes over the paint of the rocker The previous owner before me scratched the cab rocker up and I want to add these to hide the marks.
Edited by dirtfan21
Let me look tonight it's in my truck files binder
Ryan
A binder huh? And I thought I was weird for having a simple file folder. You might be on to something there.
Ordered from summit
AVS-91636
Ryan
Ryan
Ryan, that's a great idea, I think I'll give it a try. Thanks.
When I sold my 2000 I had a similar binder. Handed t over to the guy and he was pretty shocked. My wife thinks I am nuts. Told her its for records and show what has been done
Ryan
  • Like 4
Link, however they look different and are about $13 cheaper than when I ordered a few yrs ago
Odd
http://www.summitracing.com/parts/avs-91636
Perfect, thank you I typically order from Summit as well.
Side note, I keep a file on all the trucks I have had as well. Has helped me get my asking price on two trucks I've sold, the guys were surprised I kept such good tabs on things. I should really do what you do and organize things in a binder, I can tell you are an engineer.
Got a manilla folder for every vehicle I own, including motorcycles, dirt bikes, and the ATV.
The car ones are at the bottom. You can see my '74 RD350 folder labeled on the left - it's thick because I did a frame-up restoration on it.
The 2 super-thick & worn out ones in the middle are the '89 S10 Blazer I just sold, and my '07 Silverado. Sad how the '07 is one of the thickest ones there .. and it's the newest vehicle I own, with the least miles. Hmmmm ...
Next to the Silverado all the way to the right is the file for our '86 Grand Marquis - owned for 13 years, 3 decades old, with 4x the miles on it, and the folder is HALF as thick. Goes to show ya something there ...
On top all the way to the left (next to filing cabinet) is the folder for our '93 Volvo 940, also extremely thin. Needed a bit of work to get it road-worthy too. The folder next to that is for equipment I repaired, but don't own, so it doesn't count.
File thickness tells the tale ...
Sent from my SM-G925V using Tapatalk
Loose wire?
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
