How did you prep the frame for the Chassis Saver? I have some but I haven't gotten around to applying it yet.
The recovered cargo space will be really nice. The tire is the original spare, and it loses some air. When I get new tires in ~15,000 miles, I'll buy 5 I guess.
One of my tires is losing about 5 psi a week, I'm pretty sure it's the valve stem. If not, 35,000 miles without a puncture is very good for where I drive. These tires have been great.
I'm interested in this too. All I did to apply mine was wire brush the frame and wipe it down. Supposedly that's all you have to do, but I'm still skeptical because mine doesn't look all that good two winters later.
It's pretty simple. Mine wasn't very rusty, it didn't require grinding – just a little wire brushing. The manufacturer instructs you to leave a tiny bit of surface rust on it to help it bond to the fame. Then you need to degrease the frame – Simple Green is ideal – it cleans up with water. You then have to let the frame dry completely. (Overnight is best.) Two thin coats of the paint applied within 8 hours – if you let it set longer than that you'll have to sand it lightly with some 150 before you apply the 2nd coat. That's it!
Exact same thing I thought. Looks like a nice truck.
That lbz would be perfect without the stupid chrome pieces on the lower half of the door!
I'm not a fan of the chrome either but it's extremely clean I take care of it for him he hauls camp trailers around us and Canada. Son works for merchant auto so they keep it running well it's in its way to 1 million miles had 700 something I think now.
Sent from my SM-G925V using Tapatalk
I love seeing high mileage trucks personally, it's like a sense of pride to me lol
Definitely. Just wish mine had more original parts. The motor still ran when it came out, just not very smooth. Haha!
When I replaced the 5.3 in my 02 it still ran, a little sluggish and burned a lot of oil, but you couldn't kill that thing. I bet if I kept it in the truck it still would have outlived all the transmissions [emoji23]
Lol! That sounds like the one out of mine. I'd beat on that motor as hard as I could leaving work every night and it would not blow up. Crazy.
Still have her sitting in the garage. She's taking a well deserved rest. Haha!
Edited by Daryl Z71
And i cant seem to kill my transmission
What is with the 800s carpet? Does it stain easily or what? I am still looking and every one I see, especially the SUVs, have horrifically stained carpet, looks like someone was murdered or a Starbucks blew up in there.
I just think no one takes care of them. Mine looks like crap too.
People are slobs. Usually steam cleaning solves the problem.
Sent from my SM-G920V using Tapatalk
That sounds like a good idea. Any tips on what to use to do it?
Replaced all trans cooler lines today then found a water pump leak
    ChristopherDobson
    ChristopherDobson
  • Who's Online   3 Members, 0 Anonymous, 1,264 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
