Not a single problem in the 6 months I've had it, I replaced a wheel bearing that I destroyed and the tires that's it
Sent from my truck using TAPATALK
put some gas(and promptly wasted it ha) in it and drove it to campus and then did some netrual revv's when my buddy pulled up...i really need to stop neutral revv'ing the piss out of it, its killing my mpg's :cheers:
Dang it let me sleep! Lol mine's been getting less than 50 mi a week. Saving lots of money right now. Way less gas than I burned in high school. :cheers:
Sarah, 100k miles is basically new. Get to 200k, then consider selling. :lol:
damn lucky you.. 50 miles a week. i do about 800 a week
I was only doing about 120 a week last year, but many were still in my old truck. Mainly dirt road.
I guess I have had more because I have had mine for 4 and a half years, but I'm at 105,XXX miles
I got mine at 46,000. When it dies ill just rebuild
Sent from my PIECE OF CRAP DROID X2 using Xparent Red Tapatalk 2
Spent a couple hours prepping the 'Shee for the dunes this weekend, watch out Sarah it's the last run of the year for us and we have all winter to fix what we break
i just hit 123,456 miles yesterday.. waiting for my trans to go
have fun waiting mine didn't go till around 278000
Sent from my SAMSUNG-SGH-I927 using Tapatalk 2
Today I emailed Trav about some parts and I looked online for some other goodies I am getting like air bags and trying to find stock leather for I guess an SLE3 or SLT1 driver 6 way manual passenger
ill be in the dunes saturday the end of the year is great because everyone goes hard and breaks their toys last weekend was hilarious how many fords couldnt hang
idk i have bad luck.. the 4L60 in my 03 suburban that i had completley blew at 115k
I hope to only break my toy's and not myself!!!!
Admitted defeat and scraped off the ORV sticker from the truck this afternoon. Was hoping to get back on the dunes but I doubt it will happen.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
