And now my pac harness is installed for the steering wheel controls
Sent from my PIECE OF CRAP DROID X2 using Xparent Red Tapatalk 2
Ordered new tires. They only had 3 in stock so should have them put on next week
275 bfg at's :)
Ryan
Nope going black walls, I am over keeping the white letters clean. Did that in my 2000 for years
Also my truck looks to have suffered some minor damage from the valet SOB! Nick in the doorhandle
Ryan
Ryan
that idiot, do you have any touch up paint?
Thinking about an Airaid Jr for my truck with the SynthaMax filter.
Yea after I go back out to finish washing it I am going to try and fix it or at least blend it
Ryan
Ryan is your truck leveled or stock? I figure I'll be getting tires soon enough (almost at 34K!) and I'd like to take it up a notch. Get pics.
Truck... nothing. But did complete "phase one" of my dirt bike resto. Will be having my frame sand or walnut blasted soon!!!!
Starting my mini bak rack tommrow!
Sent from my ADR6400L using Tapatalk 2
2" RC Level Kit
The 275's are 33.2" tall :)
2" RC Level Kit
Maybe we're thinking of different 275s then- I might do 275/65/18. These will fit stock and be just a bit bigger. Most likely the General AT2s like I had on the Taco but I also really like the new BFG Ruggen Terrain. The photos don't do justice to how aggressive the tire actually is.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   3 Members, 0 Anonymous, 1,254 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
