I did a full clean inside on Tuesday I'm gonna ffix my scratches probably sat.. It hasn't rained in months and the day I want to strip the wax off it does lol
Sent from my truck using TAPATALK
Because they are for summer and it's not summer anymore
My apologies, I did not know they were seasonal
since i work third shift i leave at 9 and its still light out in the summer at that time and at 6am its light too.. in the winter its dark out at those time and theres snow so it only make sense to run without them
Got the truck registered for another year. Also changed to one of the "special" plates as Michigan is changing the standard one next year and I hate the design. I should be able to keep this one as all the other out of production plates are still on cars.
Found a screw in the tread of a tire. Thankfully the shop discovered it hadn't penetrated to start a leak. So I lucked out there, and then they did a rotation for free.
Drove it to take mu brother to his dad's work to pick up my brothers 4runner
Sent from my DROID RAZR using Xparent Red Tapatalk 2
Unfortunately "The Truck" gets to sit so the family pampers the wife's Jeep. Rotate tires, fluids check, wash, detail, who knows what else. Oh well it's due so the truck will be next time.
What did u use to buff that sara? It came out great
Sent from my SAMSUNG-SGH-I927 using Tapatalk 2
MALCO Tru-grit buffing compound $35 shipped
and adams drill polishing pads, they are pretty nifty
Today went out in the middle of nowhere with the truck to try out the new guns. In the morning I will put on the new MBRP catback
Drove 750 miles to get to myrtle beach
Me and my daughter as the sun came up today!
Sent from my ADR6400L using Tapatalk 2
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
