Took it on a little trail ride after trimming some bushes so I wouldn't mess up the paint too badly.
Changed the oil today, I thought about washing it but it was cold and crappy out so maybe this week.
I installed 3 piece engine covers
And a pic of me holding my new AR-15 for the first time when I went in the middle of nowhere to shoot. You can see my trucks tail light next to me
Sent from my DROID RAZR using Xparent Red Tapatalk 2
Drove 750 miles to get to myrtle beach
Me and my daughter as the sun came up today!
Sent from my ADR6400L using Tapatalk 2
We all love our trucks, and I feel like mine is the greatest thing that I've ever owned, but this is what's important. Enjoy every minute of it Tim.
Been there many times looking at the sunrise. I am only 165 miles below MB. Go there every year for the bike rally.. Enjoy it.
Question : Why would you put "Vortec MAX" on the engine cover when you don't have the 6.0L Vortec Max engine? Kind of cheesy. Sorry but that's one the the worst things you can do it put false badges on your vehicle.
Edited by BlackZ71Silverado
Procuring a 6.0 is in process. But I wanted 3 piece covers and is rater it say vortec Max than vortec 6000 for the time being. I will probably spray them so it won't stand out as much. I didn't like seeing the coils and valve covers. The covers are for my liking. I'm the one who is under the hood every week. You're not so it doesn't matter if u think it should be on there or not
Edited by chawkins6789
That little magazine on your AR is just adorable! :lol:
I'll soon have a total of 20 30-round PMags.
I'm surprised Commiefornia lets you have a rifle with the adjustable stock, flash hider and bayonet mount. Is that pre-ban?
Edited by MikeNH
It is post ban. Purchased it 2 weeks ago. And its not a flash hider its a "compensator" also has the mounting spot for the M203A1 launcher. I had to sign a document stating that by definition it is not an "assault weapon" it does not contain enough features to classify it as such
Here in America, that's just another rifle. All ya gotta do is the 4473 form. :D
I did that too. But the other paper I signed says if the law changes I have to register it
Still stupid. Gun control doesn't lower crime anyhow. Michigan has handgun registration and even that might be overturned soon. No need for any of that junk.
What's the restriction
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
