If its like mine:
Turn key to on but not start, using the driver information buttons, hit the button until you see it read something like " reset(or match) tire pressure sensor (or monitors)" push the check button and the horn will honk twice. Inflate or deflate driver front tiresfor 5 second or more. The horn will honk within 30 seconds telling you the sensor is matched to the position, if over 30 seconds, try again. After two minutes the system will reset and you need to start over. The correct sequence in order is driver front, passenger front, passenger back, driver back(aka clockwise :lol: ).
The procedure should be in your owners manual also.
I tried this on my '07 Vmax after trading a guy my 17's for his 18's. Tried until my freakin' tires were about flat, then found out that it works for relocating your current monitors, but apparently not for new monitors. This according to my last dealership anyway. I was hoping something had changed. Oh well, they'll do it for free and they're a mile from my work, so I'll let them do it- no honking or tiny little 12V compressors for twenty minutes a tire needed. Thanks anyway SnakeEyes.
For 2012 up (at least my camaro) you have to have the tool. I bought one online for $80
I washed the truck. It was filthy. Also added a vinyl carbon fiber bowtie to the camaro
Oh yea filled up the truck. E85 has dropped below $3. It is current $2.99 :)
Ryan is your truck E85 tuned?, also what kind of MPG's do you get with E85?
Not specially tuned. Justin did the in person tune in July 2010 and I had run E85 for 7.5 months straight. Nothing special with using E85 that he noticed. I think its been over 2 yrs since I have run regular (93 octane) gasoline.
I usually get between 11-12 mpg on E85 (note on my 2000 running 87 and same trips I was getting 12 mpg). Since I went up to a larger tire size it has dropped to about 10. I need to drop in the tune justin sent to correct the tire size. Doubt it will change much as these tires are much heavier than stock.
Edited by RyanbabZ71
sounds like I'll be buying the tool if they start charging me in the spring to change back to the 22's...Ryan, did you calibrate the speedo for the tire size? Are you calculating mpg old school or by the dic?
I do it in excel by the milage/number of gallons pumped. I have been seeing the DIC higher by .3 of a gallon. Last fillup DIC said 11 and it calculated to 10.7
I still need to upload the revised tune for the tires.
Here is the gm tpms re-learn tool I have (not my photo found on internet)
Used the other truck (02' 2500 HD) and cleaned up my back yard. Three trips to the town drop off for yard debris, leaves, branches, etc.
Edited by sixathome
I got rid of the stock wheels on my Tahoe; they were Goodyear Wrangler HP's. I hated them. I ordered some new BFG Rugged Terrain's. and I LOVE them. I had them on another truck I had, and they handled driving to Alaska, from MA., in the Winter just fine. I wanted to get something better on my truck, before the snow started flying around here. It is supposed to snow tomorrow.
Finally aimed the 4 PIAA 520 SMP ATP lights mounted to the front of my truck (smittybuilt light bar) last night. Drove to my hunting spot this morning and they were awesome.
Thanks Ryan. I googled OEC T5 and the first hit had it for $64.97. It looks like it also does new key fob re-learns as well. Might have to have one of these, I found a brand new fob(and key) to the '07 Vmax I traded in on this truck. HMMM I wonder where that thing is parked....
i hope that I have your luck Frogfish. I'll drop the page in my favorites in case I lose a remote. (actually my wife but she's watching me type this). Crap, she saw me.
you know what i did? alot.
did it include dumping the exhaust?
if i ever dump my exhaust ill let you come over and watch
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
