DIDNT install the new bowties. FedEx shipping delay...... :(
Lexol'ed the leather and install Carseat seat protectors by Prince Lionheart. seem like a decent product.
Edited by SnakeEyes 325is
Today I took the truck and bought 2 new subs and a new amp. My current setup is 4 years old. Replaced door speakers last month and deck in June. So the subs and amp are the last things
Sent from my DROID RAZR using Xparent Red Tapatalk 2
What did you get for subs and.amp?
Old: 2x JL 10w1v1's-4 and a power bass 800.1 mono amp.
New: 2 JL 10w3v3-4's and a JL DX600/1 for the amp.
Its about half the size of the old one but yet puts out 200 watts more RMS
Picked up a set of factory 18" takeoffs with Goodyear Wrangler SR-A tires on them for winter.
Now it will look like a true sleeper with the 18's.....until you hit the go pedal, lol. Is your truck a 4x4?, also what do you have for an exhaust on it?
TODAY
oil change
degreased engine
layed down more bedliner
tinted windows
re wired subs
pics
Judging by the tires, it'll look a bit dorky, but they have to be better than the 305/40 R22 G force summer tires that I'm rollin' on right now. It is 4WD, and the exhaust has a split tip that says Callaway but I'm pretty sure that it's the Corsa sport exhaust.
Reset TPMS. Easy, but more complicated than it needs to be
Can I do that myself? I know I can if I rotate but thought that new TPM's were a different deal and had to have a tool(not the mechanic) reprogram them. My dealership won't charge me since I bought the other set from them, but I'd do it myself if I am able. Good dealership, bought the truck there, got the new(15 miles) 18" take offs with the afforementioned Goodyears and TPM's still in them for $800.00...
Edited by SILVERADOSC540
    ChristopherDobson
    ChristopherDobson
  • Who's Online   2 Members, 0 Anonymous, 1,207 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
