Not recently, but a bit of quick research gives me the impression that it isn't where I'll plan my next family vacation.
Wise decision, I work on the North End of Saginaw and have to pass through the hood to get back home. I do not stop for anything, just get out as fast as I can
Mike, I also carry ALWAYS, still stay away from inner Saginaw and most of Flint
Edited by NitroCherokee
Hauled all the ill gotten booty from a night of shopping!!! No dead bodies came with me. Its done for another year. :jester:
Drove my awful rental Nissan to visit some friends for dinner while in NH. Their son, who is 8 liked holding my AR. :lol:
Just got home truck Is a great travel buddy and so is he
Edited by SarahsGMC
Its that time of year again so I put on my other shoes for the winter
Its an older photo but the tires and wheels haven't changed.
Limped the truck down the road to play poker. I do have to say its not acting like it has blown anything. I'm having a compression test done Monday if I get a chance.
Today I didn't have to use my AK so I got to say today was a good day.
Sent from my DROID RAZR using Xparent Red Tapatalk 2
i say this on the regular lmao
It was my song of the day
Ordered my clear corners to match my newly done heads, new brakes, new u joints, and new speakers. Also put a new system in the car!
Sent from my SAMSUNG-SGH-I927 using Tapatalk 2
Sitting at Meyers Chevrolet getting my heater fixed fo free
I set the appointment for my 6.0 swap
While waiting the manager came to me and mentioned an application i put in a couple years ago for detailing said he's gettin back into it and might need someone said if I was interested in part time work leave my name and number awesome!
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
