Tomorrow I will be changing oil pressure sensor, transmission fluid and differential fluid.
I'm getting extremely tired of the shitty cold starts that only get worse during the winter. So far I've read that it is caused by a bad intake manifold. The maf or anything else might to be blame?
Sent from my SM-G550T using Tapatalk
All fluids changed, oil pressure gauge back to normal and check engine light gone.
Always a possibility - intake leaks = LEAN, lean = hard starting when cold.
Could be any air leak - vacuum booster hose, etc., bad o2 sensor, coolant temp sensor ....
Best course of action is to get a scan tool on there and read the live data. Gotta own one if you own a '96+ anything, because you WILL need it eventually - like death and taxes, I can guarantee it.
Edited by Jsdirt
Today's the day for hauling Fords, I guess. :lol:
Just grabbed this gem for my neighbor. Free. Drove it on and off the trailer in 4-low too. :D
'93 F150, 302, 5-speed. Man .. I remember when these things were brand new sitting on the dealer lots! Seems like just yesterday. Time hasn't been to kind to this one. 24 years of MA winters.
I watched the front bumper corner flap up and down over every bump. :lol:
Only crappy part about dovetail trailers. Very low ground clearance when the tow vehicle is on uneven ground. Turned it into a plow ...
Doesn't help that it's 45° out there right now. Heat wave!
Edited by Jsdirt
Haven't done anything in the shop the last 2 days with no electricity. Ice storm took most of my trees down. Felt like crying yesterday morning. Spend a lifetime nurturing the trees on your property and Mother Nature strips them of their branches limb by limb.
Edited by Coby7
Sorry to hear that, man. Sucks. We had a similar storm roll through here in '08 - knocked out power for a week.
Want to see a pampered society melt down? Shut off the power in Massachusetts for a week! :noway: That's the only thing that will get people off their asses and into the streets today ...
Some pics from that '08 storm. Beautiful, but boy did it do some damage. Cost people lots of money. Thankfully I wasn't one of them, aside from a few oaks that came down. I could hear branches snapping left and right when I woke up that morning - knew something was wrong ... :
Ice%20storm%2008-09%20%20012_zpsdghau35w
Ice%20storm%2008-09%20%20015_zpsvlrqbrim
Ice%20storm%2008-09%20%20009_zpselnzzjrh
Ice%20storm%2008-09%20%20017_zpspmzewoih
Ice%20storm%2008-09%20%20016_zpsjdigqvn9
Drove? Mine was pushed on and off.
Well, that's because it was built in the 21st century. :lol:
240,004 miles
I think today's wash was the first of the year! I also vacuumed out and wiped down the interior as usual, and re applied RainX to the windshield. I love not having to use the wipers at high speeds when it's raining.
She was then filled up with 91 and aired up to 40f/38r.
Up next is the fuel filter, cabin air filter and washer fluid cap.
Edited by white1500
I used to use that stuff when it first came out. Was great having the rain bead up and blow right off the windshield.
I'm sure they've changed the formulation over the past 25-26 years, but back then, the stuff would "wear" off, and make a pretty dangerous situation. I recall scrubbing my windshield with a soapy sponge trying to get the residual off - nothing worked! Had to keep using the stuff. Made the wipers streak something fierce, even with new wipers! I wasn't too happy about that.
Around that same time they came out with an anti-fog bottle - I used to use that in my dirt bike goggles. Worked great ... again ... until it wore off. Then they'd fog up 10x worse than before.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,347 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
