The GTSR W1 :driving:
So what are you making room for? I still kick myself for not buying Justin's 03 SS or your TBSS
How about it. I'd have bought that SS if I was in the market at the time.
LOL!
OK so we have a 2015 Chevy SS (with a Whipple 2.9) but I would sell that in a heartbeat for the new GTSR W1.
Edited by Jennabear
Loving this weeks weather
But also had to send my cluster in. I see this now
I have noticed I am driving at higher speeds because I don't have the needle catching my eye.
I remember when mine looked like that, I didn't drive mine though.
I guess they changed it after the 02 model as to where it calculates the odometer? My truck did it in the cluster
Sent from my SM-N920V using Tapatalk
It calculates speed in the computer. It can be displayed through the datalink port. Scangauge is giving me that info but it is not in direct line of sight.
And some people are poor so they only have one vehicle. I'm poor and about to get boned by the IRS. No romance. No lube.
Hahaha! I'm sorry, I have three to choose from. :lol:
Replaced cabin air filters, both around 1.5 yearsold or so old
Silverado
Versa
Sent from my SM-G550T using Tapatalk
Nice of them to "thank" you for your service ... :mad:
Pretty sure if you remove the cluster from my truck (2007), it'll start once ... then won't again, so you'd better have a good destination in mind ... :lol:
    ChristopherDobson
    ChristopherDobson
  • Who's Online   2 Members, 0 Anonymous, 1,207 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
