I know you have prime so free shipping
You hack my info or something? Haha! I like the second one better, too bad it's not as fancy though.
I didn't pay $50. Got mine locally
Lucky you.
It is stronger than the $50 one and it is tacti-cool. And you post on Facebook about the grand tour. That is a giveaway
Forgot about that. Haha!
I've seen those cases of all sizes get abused and things all good. I've also seen the case shipped usps from trashcanistan full of stuff with just a postage label on it
Not a bad deal then for around $25. I'd buy this one.
I'd recommend a grocery bag.... mine was free with purchase of some groceries.
Sent from my SM-G920V using Tapatalk
Because of idiot voters here, they charge for bags
lol Chicago has followed California's lead
Miles: 243,311
Tires were rotated at Costco during lunch, and i asked for the weights to be installed on the inside instead of the outside for a cleaner look.
The next (scheduled) items are the fuel filter and belt.
Sent from my SM-G550T using Tapatalk
Edited by white1500
Won't fit in the glovebox?
Sent from my SM-N920V using Tapatalk
You don't want to keep electronics in your vehicle. The change in temperatures and humidity are horrible for them. Especially these cheap Autocals.
Sent from my SM-G930V using Tapatalk
Today sold and programmed 2 FOBs for a 2008 Buick Enclave.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   2 Members, 0 Anonymous, 1,207 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
