Drained transfer case oil and only a quart came out lol. It holds 2 quarts. Must have leaked out.
or it was never filled to the limit?
I drove mine to a buddy's house yesterday afternoon, and then back home this morning. Went 142 miles round trip, and pulled down an average of 17.6 MPG. I ran down yesterday at 65 MPH with the A/C on pretty much full blast. Not too bad for an older truck with 6 ply LT tires.
Edited by Daryl Z71
#repost
It was already on Facebook
Today I pulled off the steering wheel cover/air bag and replaced the little tin plate chevy emblem. Now it looks new and smooooth. And.. I removed the tube steps as they were getting rusty and already had a hole rusted thru on one of them. Drivers side was a PITA to get off, the bolts were rusted. Passenger side came off quite easily compared. I'm assuming these were put on by the original owner of the truck back in 2012 when the truck was new. But given how well they rusted up, I don't think I will purchase any products from Iron Cross.
This is what they look like new.
This isn't Facebook.
You posted the same thing on facebook
I know, but this is GM Trucks not FB lol
And here, I have the power
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,012 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
