Drove down to Louisville this past weekend for my brother-in-law's grad school graduation and I swear I hit every bug on 65. Finally got to wash her up tonight with the Adam's. God I love this stuff. Hit it last week with H20 Guard and Gloss after a wash and the bugs just fell off tonight. So worth the time and money.
Made some spacers for the bumper bracket so I wouldn't have to weld a new core support bracket on the frame
Very ingenious of you. Nice job!
$2 of aluminum isn't bad. I think the bolt cost more than the aluminum.
Washed both trucks. The 2010 has trim falling off.
This came loose behind bug shield, 7 outta 8 clips broken. Think I have to readjust grill. Driverside Corner a hitting.
Then the door knocker trim is becoming loose. Gotta stop going to the big truck washes. Just peeled off passenger side. Gotta restick.
I went back to an engine driven fan. This time with parts out of a 2500HD. Shroud needed some convincing from an angle grinder and self tapping screws to mount up
Permanent or temporary?
I ripped the leads out of the PCM
-10 hp
Sent from my SM-G920V using Tapatalk
And -1 MPG. But it was dyno tuned with an engine driven fan. But I'm having issues with the electric fans. Repeatedly. Last night it took 40 minutes to go 3 miles because of an accident. I was at 230 with the heat going full bore
Get the flex a lite fans I had on my 02, they made a good bit of noise but I never had issues with them
Sent from my SM-N920V using Tapatalk
If I go that far, I'm going to spend the $1200 on their fan and radiator setup. My problem was the electronics. The harness I had was just long enough. So relays would melt from the fans blowing on them. I also have to change the water pump. It is leaking behind the pulley. I have a drip pan underneath the truck for it.
Edited by Chris
Put drive shaft back in. New U joints. $41 for them and $53 to get them installed. $110 total.
Ordered my water pump and coolant bottle today.
I drove to Knoxville and back on Thursday just to shop and eat at the Cheesecake Factory with my girlfriend. Pretty impressive with the gas mileage in this truck. Driving 70-80 mph pretty much the whole way. I could have drive another 25-50 miles probably. 14 CC LTZ 6.2L
Edited by STINSAN3
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
