Glad it's not a RED tag. :D
When I drove for WM, I got yanked by DOT and red-tagged on the spot! Had to have the boss pick me up.
When the trooper asks, "Do you mind if I use foul language?", in order to describe the condition of the front end, it's pretty bad. :lol::lol::lol:
Put around 400+ miles on the truck over the weekend towing the trailer with our two bikes on it. Left it in 4th gear and let her eat. She screams but that's where these engines make that torque is 3k rpm's and above
Crossed 78k miles on the way home. Me and dad were talking about getting another trailer so we can haul a lot of other bikes too so it'd be a gooseneck, about 30 foot deck or so. Which would mean one of us getting a bigger truck, guess time will tell [emoji106]
Sent from my SM-N920V using Tapatalk
What is it?
Sent from my SM-G920V using Tapatalk
Safety inspection - usually done when you stop at a weigh station, but they can yank you at any time rolling down the road.
That's right where mine starts making power too ... and starts burning oil. :sick: Just hope I have a lift when this thing finally grenades.
Nice lookin' toys ya got there CJ.
Thanks, and yeah added 2 quarts before we hit the road as well. I don't get it, practically brand new truck and goes through that much between oil changes often
I'm just amazed that GM doesn't see this as a problem. You'd think they'd have fixed this by the '08 model year ... but they just made them worse. :nonod:
Maybe GM should stick to building gliders, and let the customers choose the driveline. I'd probably buy another GM again if that were the case! :)
Yup, passing inspection. Got run down last week also.
Cops are after those campers haulers going 62 mph on the interstate.
I'm open for business...
How did that quad handle the water?
Handled it fine besides the fact the belt started to slip, or the clutch went bad [emoji23] [emoji23]
Gonna clean it up today and tear it open, see what damage I did to the CVT system
Got my oil analysis back. The trend confirms my engine's decline began a couple years ago.
90k miles! THANKS GM! Nice F#%&ing job on that one!! :mad::mad::mad:
The wear metals tell me it's more than likely the cam bearings - been seeing alot of those types of failures in these AFM engines across the net. Also piston rings add to the iron content, and pistons to the aluminum. Seems the aluminum content has gone down since I switched to 10w-30. Was high on my first analysis.
Glad I didn't use this thing to commute the entire 10 years I've owned it - would've needed an engine back in 2011! :sick:
How long you been running Amsoil SS in your truck?
Since it had 40k miles. Ran Royal Purple before that since it had 2,291 on the clock. Always changed that at 5k miles or sooner. Alot sooner than it needed to be, that's for sure.
Couldn't do any better maintenance. Treated this one the same, if not better, than my old school 350s I've owned in the past, and this modern junk hasn't even come close to the miles (or the severe beatings) those engines had on them. I was in my teens and twenties in those days - the pedal spent most of it's time planted in the carpet! This truck was babied by comparison. It's a friggin disgrace! :mad:
GM has forgotten how to build an engine in order to save themselves some money. Maybe if they built the shit right the first go-around, there wouldn't be any money problems? HMMM! What a concept!! :eek:
You might have just got some water in the CVT cover. Just take that plastic drain plug out (see if any water comes out), then fire it up, and hold it at 3k or so for a couple minutes - that should dry everything out in there.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,012 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
