Someone's confused! :lol:
Started painting. John Deere paint
Or it was a prank
"Socialised" it from a Chevy owner.
Edited by Chevor
I'm just amazed that GM doesn't see this as a problem. You'd think they'd have fixed this by the '08 model year ... but they just made them worse. :nonod:
Maybe GM should stick to building gliders, and let the customers choose the driveline. I'd probably buy another GM again if that were the case! :)
I heard BMW is now telling V8 M car owners that "when it says it needs a quart, add two". I'm they burn oil so fast I doubt you would even need to change the oil.
Not surprised. Gotta love the 21st Century way of quality control, & customer satisfaction!
It's so friggin easy to build an engine that doesn't use a DROP of oil! I've been doing it since I was 16 years old!! :nonod: That's just unacceptable on so many levels ...
Edited by Chris
Just reminded me I forgot to look up that tranny cooler you got there. That's a sweet one.
Well, my engine is probably going to grenade in the next year or 2 ... or sooner, so I should be saving for that first ... :throwup: Such a downer ... :nonod:
Edited by Jsdirt
It's a Fluidyne ThermHX
Got off work and my buddy and I did a quick inspection of my truck in the parking lot, then did a road test. We've concluded that the tires are most likely the reason I have shakes/shimmies while driving. Some of the tires have bulges on the sidewalls. Left front is probably the worst. So now I get to see how and if I can get them warrantied by Michelin. Also stopped by my rental property and had them double check the tires real quick and took a better look at the bay doors I'm going to need to replace. Also dropped off my 12T jack stands at storage to get them out of the garage since they are too tall to use easily on my truck. In about an hour or so I'll be driving to the other side of town to go to a baby shower.
Edited by Chevyguy85
Ordered some Wagner brake rotors for the front of the truck yesterday, the Powerstop rotors must have gotten messed up from the junk calipers I had on before.
Hauled $42.50 in singles from auction. Also have about 90 gallons of fuel aboard.
Edited by Chevor
Finally​ got the tires from my 2011 installed on my '15. Liking these wheels a lot more with real tires on this truck.ef60ead9e9978b9348557d709e5edf97.jpg335b2f52b255aac8d13c9f005e0bb26c.jpg572335626988665a305379bd449539cf.jpg
Sent from my E6810 using Tapatalk
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,347 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
