OFFICIAL Remington 870 thread
Chris
Well Ill try to explain. I got my gun in June 2010. That was about 4 months before I hurt my back. I'd go out shoot 100 shells. Shoulder would be sore. After I hurt my back after about 30 shells I'd be sore in the back and shoulder would hurt like normal. If I shot stationary targets and rested the gun say on the bed rail of my truck, no problem with my back, just shoulder from recoil. I use the new grip and pull the gun to my shoulder so I don't do as much with my left arm. Its not supporting the same weight so to speak I shifted a little. Could be my imagination but I went out 2 weeks ago and put 150 shells thru it. A little sore in the back but not as bad as before. Shoulder hurt like hell though because I hadn't shot the 870 in over a year.
Sent from my DROID X2 using Xparent Red Tapatalk 2
  • Replies 75
I looked into a tactical style but I like the ShurShot stock.
i wasnt really a fan of the sureshot stock. i know it performs well i just wasnt feeling the way it looks. plus i like adjustable length
The length is about the same I think as the normal stock which is fine with me. Its a lot more comfortable and hell to each his own. Make it yours and perform well. I'd like to get a second 870. A tactical. And I'd love a versamax
Here's my two HD options an my carry. The stock on the 870 absorbs everything I've put though it
i have an 1187 versamax in mossy oak. amazing gun. never jams
It's a shotgun, it shouldn't jam. The shooter controls ejection, unlike a pistol or non-pump action rifle.
Sent from my iPhone4S
using Tapatalk
its a semi auto shotgun
Didn't mention that before....semi or not your shotgun should never "jam". I have never had or saw one fail to eject. Some race guns may due to their modifications but these Remingtons are definately bullet proof!
I'd like to pick up a semi one of these days too. Would like a Benelli but that's a ton of $$ for a shotgun.
using Tapatalk
The 1187 is different from the VersaMax. The VersMax is their new model. it will cycle seamlessly between all shells
http://remington.com/product-families/firearms/shotgun-families/autoloading-model-11-87.aspx
http://remington.com/product-families/firearms/shotgun-families/autoloading-versa-max.aspx
using Tapatalk
I helped my aunt and uncle shop for each other for christmas. i had him get her an iPad to make her job as a real estate agent easier. she can view propeerties on the go or while standing with a client. I had her get him his dream gun and yours a Benelli Vinci. the Camo one. I shot it. I fell in love with it
ohh i thought it was still called an 1187 versamax. mine never came with a box or anything.
most of the semi's me and my freinds have tend to be a little bit older and they sometimes jam or fail to eject.
Here's a pic of my most modded 870 Express. I'd like to get a Mesa Tactical Urbino pistol grip stock, but I would really miss the extra shell capacity of the Speedfeed.
Had several over the decades...down to two right now.
Newer 870 Ultramag Express that takes 3 1/2 inch shells is the new farm truck gun. Replaced the 26 inch barrel with the 23 inch turkey tube, has a mod. choke tube in it right now. Also replaced the plastic trigger guard with an older aluminum one.
Older Wingmaster with a 20 inch barrel sits under the counter at my liquor store. Loaded with 2 3/4 magnum double ought buck.
I actually prefer 1100s for most hunting uses.
Where did you get your add ons for the shotgun?
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
    • If I forget the phone in the truck, and forget the truck in the phone, and reconnect.  It works great for the day.  Truck sits overnight, and the next day is a no go.  It will connect Android Auto via usb cable, but not bluetooth.   Ive tried Everything in this thread so far, and nothing works for more than a day.   I think I might have to go to the dealer and have them flash the pcm.   thanks for all the suggestions guys. 👍
    • 2022 2500HD Crew Z71 Duramax single alternator.  Recently had the primary (water pump / fan) belt tensioner pulley bearing to fail while hundreds of miles from home of course the plastic pulley melted and belt shredded which took out some wiring. Found a replacement tensioner assembly and belt to continue now would like to find a replacement for just the pulley and bearing to have a spare assembly in case of a repeat, the rest of the tensioner is fine. Has anybody here found a correct replacement part for just the pulley and bearing? Any help is appreciated.
    • +1 for the 3.0   Perfect for 1500 pickup towing duties.   Perfect engine for a 1500 pickup period. Huge torque at stunningly low RPM makes it feel a lot lighter than it is. The fuel mileage is insane for a tall and heavy 1500... 30+ on the highway. Mid 20's around town.   It's probably not perfect if you bought a 6.2 for the braaaaaaapppppp V8 noises and wrapping it out to 6k. The LZ0 acts and sounds like a small turbo diesel and there's nothing you can do to make a small turbo diesel sound like a big one, and you can't make an inline diesel sound like a V8 diesel/big Duramax. It's a different driving experience altogether.   Drive one, I think you'll like it, though...
    • I'll bet your truck lost the bearings on a roller on 1 of the lifters, and now is wiping out a cam lobe.
