What should I do with $260
I guess this is the right place for this question.
Ive got a little expendable cash and I want to spend it in one of two ways. Im either wanting to get an Autocal from BBP, or upgrade my pillar gauges to digital.
My truck needs a recalibration for the 35s I just installed, so I already need Justin to tweak my tune to compensate.
I could go the Autocal route because that would save me the down-time and hassle of shipping my PCM, or trying to get a crank relearn on a spare PCM.
It would save all the mentioned above time and hassle if I ever got a regear.
I can use it like a scan tool to clear my annoying P0442 code.
I could have a couple more tunes available to install if I wanted them.
But, after I get the tune adjusted to my liking, Im not sure that I would use the Autocal much anymore. I dont want it to be a waste of money that i could use somewhere else on the truck.
Im at an impass and need some input.
If you have an Autocal, how often do you use it to switch tunes, scan, etc?
Not gonna happen. The primary purpose of my rig is to get me to work, do some light hauling and towing, and crawl around in the woods. Train horns wont help improve any of those.
While they might be a blast on the highway (pun intended) I wouldnt be able to justify them to myself.
I like using the AutoCal to switch my tunes to stock if taking to the dealer for service or warranty work. They ran a scan on my truck last week while it was in for service to make sure the updates were there and all was fine. My service advisor was shocked nothing came up as I had the BB tune on my truck at the time. He's been wanting an AutoCal as well but just hasn't saved the cash yet. I also like the autocal for when I switch to E85 or run 93 octane here in Houston. I know I would never leave the stock program on it since it is so horrible with the AFM, etc.
Well, my truck doesnt have any warranty left, and all of my service that gets done by anyone but me is done by my local mechanic. I have thought that it might be nice to switch between octane ratings and see where my mileage ends up.
I have also been reading up on Cyberdyne gauges and I dont think I want to spend my hard earned money on them.
So I guess now it comes down to wehter or not I feel that the autocal would be worth it.
Dont really need a winch either, no snow, no rain or rocks, and the mud I go through is nothing the truck cant handle on its own. Thought about getting one, but I had one on my 01 Wrangler that I never used. Litterally only used it once to pull a hog trap out of the brush. Just another option that I couldnt justify.
take your parents to supper ,do that instead bud ,forget your truck
corrected. buy tow mirrors on ebay for 170 like me, and still take your parents to supper too
tow mirrors
Thought about that just the other day. I always thought, "whats the point on a half ton?" but with the size of my truck, I think they might be justified at some point. Its just that I need to get my speedo adjusted ASAP so my odometer stays somewhat accurate and I can actually figure my MPG accurately.
We are already planning a party for them. Asside from both of them turning 50 this year, it is their 30th anniversary. So thats already in the works.
Cam, or headers...
I didnt think about that. While Im not ready for that now, I would concider that another handy reason to have the Autocal. I think Ill do it. Im gonna bite the bullet and order my Autocal today, hopefully. I forgot about all of those mods that will be in my distant future, like a cammed 6.0, headers, gears, and other stuff that Im sure Im forgetting. The Autocal would make it much easier to make changes in the computer when that time comes.
i thought the same thing about tow mirrors, and i was hesitant to get them but if you have a lifted or level 1500 with bigger tires they look more in place
  • 3 weeks later...
I did a raylar cam in my 8.1 andd im VERY happy, next im getting a set of long tubes from stainlessworks,
but 1st if i were you i get an in person blackbear tune with justin, if not in-person get the autocal...I got it and had a tough timme in the beginning, but got it figured out..Very goodd tool/toy to have!
I already have a face to face tune, but I decided to get the autocal just so I can have changes made faster and easier than mailing my PCM or having to pay for a crank relearn.
    • I had a new engine installed with under 5,000 miles. It shut off coming around a residential street corner and wouldn't restart. Dealer indicated it seized. New one has been fine since with 10,000 miles on the replaced engine. Annoying but I was given a loaner for the 5 weeks it was down. I won't go with the 6.2l gasser so it's 3.0l again. I love the economy and it tows my enclosed car trailer just fine.
    • Coming back from towing a car to my daughter in Nashville truck started making a screaming noise from underneath.  Pulled over placed in park and sure enough whining noise from underneath.  Dropped at the dealer fearing new tranny or another front pump/cover replacement.  Service writer said it sounded like the tranny too...  Well $300, new idler and a belt all is good.  Pop the hood and give a listen. lol  Now I'm telling dealers I'm no longer interested in a new truck.
    • HD uses the 6.6 gas.   Oil consumption while heavy working is considered normal.  1 quart per 100 gallons of fuel is the normal rate above 8600lbs GVWR.  If more than that, it is considered excessive.   They will have to perform an oil consumption test using the guidelines in TSB 03-06-01-023J.     Information on Engine Oil Consumption Guidelines All engines require oil to lubricate and protect the load bearing and internal moving parts from wear including cylinder walls, pistons, and piston rings. When a piston moves down its cylinder, a thin film of oil is left on the cylinder wall. During the combustion process, part of this oil layer is consumed. As a result, varying rates of oil consumption are accepted as normal in all engines. Oil Consumption Oil usage has a direct relationship with the amount of fuel used. The harder an engine works, the more fuel and oil it will use. Therefore, oil usage as a factor of fuel usage is a more accurate indicator of acceptable oil consumption levels than vehicle mileage for vehicles at or above 8600 GVW. The accepted rate of oil consumption for gasoline engines in vehicles at or above 8600 GVW is 1 liter (1 qt) within 400 liters (100 gallons) of fuel used. This rate only applies to vehicles under warranty, maintained in accordance with the appropriate maintenance schedule, driven at legal speeds and within design intent of the vehicle. Many factors can affect an owner's concern with oil consumption. Driving habits and vehicle maintenance vary from owner to owner. Thoroughly evaluate each case before deciding whether the vehicle in question has abnormal engine oil consumption. Gasket and External Leaks Inspect the oil pans, engine covers, and the engine oil cooler for leakage. Inspect for oil leakage into the engine coolant. Improper Reading of the Oil Level Indicator (Dipstick) The vehicle must be parked on a level surface to obtain accurate oil level readings. Verify that the dipstick tube is fully seated in the block. When checking the oil level, make sure the dipstick is wiped clean before taking an oil level reading and fully depress the dipstick until the shoulder bottoms out on the dipstick tube. The dipstick should be the proper part number for the engine/vehicle that is being checked. Not Waiting Long Enough After Running Engine to Check Oil Level The vehicle should be allowed to sit for at least 15 minutes, after the engine has been shut off, before taking an oil level reading to assure the oil has had enough time to drain back into the crankcase. In order to ensure accurate results, the temperature of the oil should be close to the same temperature as the last time the oil level was checked. Improper Oil Fill After an Oil Change Following an oil change, verify that the proper amount and type of oil was put in the engine and that the oil level on the dipstick is not above the full mark or below the add marks. Refer to the Owner's Manual or Service Manual for information on recommended oil quantity, viscosity, and quality. High Speed or High RPM Driving Continuous driving at high speeds/high RPMs may increase oil consumption. Because this may not always be an everyday occurrence, it is hard to determine exactly how much the oil economy will be affected. Towing or Heavy Usage Towing a trailer or hauling additional weight will increase oil consumption. Large frontal area trailers will further increase the work required from the engine, especially at highway speeds, and thus increases the rate of oil consumption. PTO Operation Operation of a PTO will increase fuel and oil usage, as the PTO driven accessory uses engine power to operate. Crankcase Ventilation System Verify that the positive crankcase ventilation (PCV) system is operating properly. Blockages, restrictions, or damage to the PCV system can result in increased oil use. Oil Dilution from Condensation On vehicles that are usually driven short distances, less than 8 km (5 mi), especially in colder weather, condensation generated from cold engine operation may not get hot enough to evaporate out of the oil. When this occurs, the dipstick may indicate that the oil level is over-full. Subsequent driving on a trip of sufficient length to enable normal engine operating temperature for 30 minutes or more, in order to vaporize excess moisture, may give the customer the impression of excessive oil consumption. Engine Temperature If an engine is run at overheated temperatures (see Owner's Manual or Service Manual) for more than brief periods, oil will oxidize at a faster than normal rate. In addition, gaskets may distort, piston rings may stick, and excessive wear may result. Verify that all cooling system components are in proper working order. Engine Wear Piston scuffing, excessive piston-to-wall clearance, tapered or out of round cylinders, worn, damaged or improperly installed valve guides, seals and piston rings will all cause an increase in oil consumption. Measurement of Oil Consumption Engines require a period of time to BREAK IN so that moving parts are properly seated. Therefore, oil economy should not be tested until the vehicle has accumulated at least 6400 km (4000 mi). An exception would be allowed only if an engine is reported to be using more than 0.946 liter (1 qt) in 1600 km (1000 mi).   Verify that the engine has no external leaks. Repair as necessary. Verify that the engine is at normal operating temperature (see Owner's Manual or Service Manual). Park the vehicle on a level surface. Wait at least 15 minutes, after the engine is shut off, before checking the oil level to make sure that most of the oil has had time to drain back into the crankcase. Check the oil level and record the vehicle mileage, date, and exact oil level on the form included in this bulletin. Next ensure the oil level is at, but not above, the full mark on the dipstick. add oil if necessary. Also ensure the proper viscosity and quality oil are being used as recommended in the Owner Manual Ask the customer once they have consumed 100 gallons of fuel schedule an appointment and return to the dealer for inspection. If the final evaluation shows that the engine uses more than 0.946 liter (1 qt) in 379 liters (100 gallons) of fuel used, follow the published symptom diagnostics as described in the appropriate Service Manual. If the oil consumption test shows that the engine uses less than 0.946 liter (1 qt) in 379 liters (100 gallons) of fuel used, explain to the customer that their engine meets the guidelines for oil consumption.
    • I have a 2024 Chevy Silverado 2500 with the 6.2 liter engine, Vin: 2GC4YME79R1273849, with 27,437 miles. Recently we took a trip from Candor, NY to Townsend, TN pulling our fifth wheel, when I got close to the Townsend, TN area The truck gave me a message of low oil. I checked the dip stick and found it was 2 quarts low. Today, August 27, 2026, I had the oil changed and the technician Found the truck was very low on oil.  Is there a Recall for this? What is my recourse for this issue? Do I call the dealer where I bought it or any chevy dealer?   Robert Strickland 292 Owego Road Candor, NY 13743 352-502-6588 [email protected]
    • We understand the importance of understanding how your Sierra performs, @SoCal Angler. Our team would like to gather the proper details to assist you with your inquiry about your truck's automatic braking. When you have a moment, please visit: https://s.chevy.com/support-request and fill out the request form with pertinent details. This will ensure your request is routed correctly so we may take a further look. We will keep an eye out for your outreach.
