LOL, I can say it is a very fun gun to shoot. Very smooth. We took it out to BLM land yesterday and had a blast, we both commented on how it was one of the best rifle purchases we made.
If you guys provide the ammo, sure you can shoot it![/quote
If you guys ever do another tune session out here you should bring it. Tuning trucks and shooting guns sounds like an epic weekend, am I right? :lol:
They have never lost any of mine
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
They have only handled my 870 and my 1911. I have only driven with the AR. Which sight is on it. Looks like EOTech. I have the EOTech EXPS-2 on mine
What is the magnifier? Also what did it run
Sightmark 3x, I would have to go back through to find price, but we get good deals on optics.
Sent from an ice cream sammich.
Wouldn't trust them with that gun and those optics.
You get to lock the case with real locks, not stupid TSA locks. They keep a tight control of firearms in their care. I spent a lot of money on a Pelican case ($400) and it keeps t protected. Can't say I blame ya for not wanting to, I'd much rather drive places than fly.
I have been on several flights for work related reasons and haven't had a firearm misplaced. Just make sure you have a proper airline approved, lockable case to transport on the airplane.
I use a Pelican case with custom foam for an exact fit with my select fire Colt M4 and pistol including magazines. Not sure how much it really costs, ordered through work.
Edited by BlackZ71Silverado
Where did you have the foam cut or did it come cut? I'd like something like that for when I go shooting. Lock it and chain it in the bed in case I stop at a gas station
casesbypelican.net. Not cheap but it fits a rifle and pistol like a glove.
Do they custom cut to the guns you have and sight options
For the pistol they had options for the M9/Beretta 92, 1911 and the M11/Sig P228. I got mine with the Sig cutout and all of my pistols except for the Beretta fit decently enough for transport because they're all the same size. For the rifle I got the M4 SOPMOD version, it has large cuts to clear optics and such. This is it:
DE2054D2-A906-4FFC-B242-64386A4A3D89-121
They can do custom too. Browse the site, they have tons of options.
I have a 1911 and all my AR has is the EOTech
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
