I have a 1911 and all my AR has is the EOTech
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
I'd expect that would fit fine as I think my Aimpoint is taller. The case is awesome, waterproof, durable, etc.
You can also get them so the foam is cut into tiny squares that are barely attached to each other. You pull out the squares you don't want and then you can customize it to fit whatever you want.
How well would they sit in the case with all egg crate foam
For the pistol they had options for the M9/Beretta 92, 1911 and the M11/Sig P228. I got mine with the Sig cutout and all of my pistols except for the Beretta fit decently enough for transport because they're all the same size. For the rifle I got the M4 SOPMOD version, it has large cuts to clear optics and such. This is it:
DE2054D2-A906-4FFC-B242-64386A4A3D89-121
They can do custom too. Browse the site, they have tons of options.
Something like that will cost $500 or more...........WELL worth it though for traveling.
You got your AR set up perfect, no useless junk hanging all over. Can't tell from the pic but do you have a light on the handguard?....Even got the red dot in the right place. Can't stand seeing them mounted on the rear of the flat top rail. They should be as far to the front as possible, just like yours! Nice set-up.
Get rid of that Sig and put a Glock in there!!!!!
When we ordered them through work, we filled out a custom sheet order and they cut the foam accordingly.
Edited by BlackZ71Silverado
That's how I have my EOTech. I didn't know how to mount it but I read the instructions. I have to figure out if I want a railed gas block or mount a flip up on the front of the hand guard
No light currently. The case was just under $400. And the Sig was just what I used for the photo, I carry my G32 or my HK45C.
That's how I have my EOTech. I didn't know how to mount it but I read the instructions. I have to figure out if I want a railed gas block or mount a flip up on the front of the hand guard Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
What do you have for a handguard? I recommend going with a free float handguard that covers the gas block entirely and then have a fixed front sight mounted on the rail of the handguard. There is no need to have a folding sight with with a reflex sight such as an aimpoint or eotech. With the dot you are focusing on your target with the dot on it and those sights will magically disappear from your vision. With irons you focus on the front sight. When you don't focus on that front sight, you forget it's even there. My rifle currently has a flip up on the front, but I bought that before I had experience shooting it. My new AR is coming with a fixed Daniel Defense front sight.
I have the Magpul hand guard. See MikeNH's pic in the case. Thats the hand guard I have. It's not full float.
Used to have one just like it. I would go with a F marked front sight post / gas block just like what mike has. Best solution for a non floated gun.
Mine came with no front sight
Right, but if you want a front sight without changing handguards you will need a new gas block. If you are replacing the gas block why not just go for a milspec FSP.
If I were in your shoes, given that your gas block is already low profile, I'd buy a free float tube that mounted to a milspec barrel nut (troy Alpha for example) and then through a fixed sight on that.
If I did it again I would like to do a railed gas block and do HK hooded/ghost ring type sites front and back. The MP5 I shot a few years back had them and I really liked the setup.
Personally I can't stand hooded front sights. My MI sights I used to run on my AR had a hooded front. They were on a railed block too. My complaint is that if your elevation doesn't land your front sight post in the center of that hood, you will not instinctively put the front sight post in the center of the rear sight. Instead you will line the ghost ring up with the hood of the front sight, and they actual post will not be in the center. If you're just going to shoot from the bench without stress it will be fine, but it makes it tough to snap the gun to your shoulder and put that post in the center of the rear sight. With the hooded sights you will tend to align the circles instead of centering the post in the rear sight.
IMO railed blocks are a PITA. You have to make sure you get one that is the same plane as the receiver. Most are not. Otherwise you have to get taller front sights to level it up. After floating my rifle, I don't think I could ever go back to having an exposed gas block. My hand typically sits right where the gas block of a midlength gas system sits. This equals burns without a float :lol: Plus I think the railed blocks are ugly :lol: But that is just person taste.
Edited by sputnik360
I haven't given it much thought to be honest because work is back into full swing and I don't have time to be screwing with it. Just seemed on the MP5 that target picture was easy to get. Plus by getting the 45 how I want it, I've given HK enough money for a bit. :lol:
I agree with Sputnik, for the most part. If you have a free float rail or are planning on a free float rail. I'd just use flip up's for the longer site radius, If you currently have a gas block with a rail, and non floated hand guards its upto you.
    Randy Ginoza
    Randy Ginoza
  • Who's Online   4 Members, 0 Anonymous, 1,921 Guests (See full list)
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
