Help with a project
Sorry I haven't been around for a while. I've been busy. As you can see from the picture my son has an interesting project. This started life as a 1957 2 ton cab over box truck. Now it has been extended with suicide doors on the back and it's mounted on a 2003 W4500 GMC chasis. The bed is from a 57 fleetside that has been cut down and widened. However it's still in the garage. My daughter-in-law laid down the law that "Big Bertha" was to be ready to tow their new 35 foot 5th wheel camper. So a wooden bed has been installed to fulfill her "wishes". The picture was taken on the maiden voyage, both for the truck and the camper.
The problem is we can't find a wiring schematic for the donor truck, and the fuse box covers are missing. We have no idea what relays and/or fuses are for what circuits. We are trying to get the air conditioner to turn on. The indicator light lights, but we can't find any output.
If anyone knows where we can find wiring information, it will be greatly appreciated.
Can't help ya, but that is one badass looking ride!
I'm with him...looks awesome!
...oh and sorry I can help you either.
Thanks guys. I know someone has the info we are looking for. He has only been working on this since November 2011. He also has a full time job. Here is another of his projects. This was somewhat of a restoration rather than a creation.
He pulled his first camper, a 12 foot Scottie, with this.
Anyone have any ideas where I can find a schematic for a 2003 GMC W4500. I would think someone would have access to a service manual for one of these. They are common.
Please help.
i need to know if the doner is a GMC or chev :
conventional or a crew or a commercial (cutaway)
better yet ,get me a vin,
i want to give you the correct info !!
Govtec4, my daughter-in-law said my son is out of town on business. I'll get the vin when he gets home. In the mean time, I can tell you the donor truck was a 2003 GMC W4500 cab over box truck. It was wrecked with only 63000 miles on it. I found it odd that it has a 5.7 instead of a 5.3 or 6.0, but I don't know much about the medium duty trucks.
when ever PM me the vin,i want to get you the proper schmatic for the truck for you ,im not gonna guess
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
