Thinking of changing my rim setup again... Hmmmm!
sab316
Okay so I have the grey GMC 20's, that I like the look of, but I'm considering switching up rims... again. Sometimes I just get a little bored :ughdance: I was thinking of going black a while back, but considering every highschool kid with a rattlecan / plasti-dip has painted their rims black I have decided to avoid that.
Yes thats right..... I'm considering going chrome. I have big chrome bumper... so why not? Chrome also looks good on a grey truck. Sooooooooo here is my dilemma I'm looking to stay as close to stock offset as possible (which is +18mm right?). Right now with the 295's I only rub sway bar at full lock.
The 2 rims I'm looking at right now are Ultra Predators and XD Badlands. Predators come in a +22mm, and Badlands in a +18mm. The +22mm offset wouldn't push them in too much farther would it? So I'm looking for opinions on which you like, and also any other suggestions. Looking to stay in the 20x9 area with a positive offset.
Truck as it sits now.
Ultra Predator
XD Badlands
i personally think it looks perfect with those rims. if i had a GMT900 id want it to look exactly like that
Factory is +31mm. I'm running +18. They run good. I've had 295/55r20 and now 275/60r20 with no rub unless pothole while turning.
Factory is +31mm.
This. I like the Predators. Understand that although you will be pushing the tires outward and away from the swaybar, they will will likely rub the outside edge of the fender.
Alot of post of keep it :lol:
Well considering I figured out my pup will have to go back to training before hunting season, and I have a few other things I need to take care of.... I'll be holding off on the rims for now...
Its still highly tempting though...
    RyGuy43
    RyGuy43
  • Who's Online   5 Members, 0 Anonymous, 460 Guests (See full list)
    • This is NOT impact damage nor neglect. There were previous class action lawsuits because of such paint preparation st GM manufacturing plant. Not just the Cherry Red Color. This paint is applied in three processes to obtain the desired color.  The manufacturer will cover for 36 months or 36k miles only. That rust is actually corrosion because of the paint process failure. Corrosion is covered for 100,100 miles or a certain months. However their corrosion doesn't include this type. Go figure. Clearly manufacturer knew from previous paint issues. This started 3 weeks ago out of the blue.
    • Is it time to put a piece of tape over the CEL?
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
