Post your MPG on Taller Tires
Its an age old conversation. We all know that you will not get Volt mileage out of a Silverado on 35s, but nobody wants to shell out money and get horrible mileage on purpose. We are all aware that we will take a hit at the pump with larger trucks and tires, but lets be honest, we all would like to soften the blow. That ultimately leads to thousands of repetative threads with one basic question, "What gear ratio should I get to keep or return my MPG?"
So, lets get a thread started about MPG for lifted trucks. Its stimple. Just post up the following info on your truck and then we can redirect those looking for answers to this thread, and hopefully someone with a similar truck setup has posted so the can make a comparison.
Info needed.
Year
Engine
Transmission
Tire Size
Gear ratio
MPG at XX mph or LPH at XX kph for our metric friends
Possibly even driving conditions or terrain
Lets see what you guys are getting.
  • Replies 41
Year: 2011
Engine: 5.3
Tranny: 6 speed
Tire Size: 295/70R17 (33.5")
Gear Ratio: 3.42
MPG avg: 15
Terrain: mostly flat (I live in the delta, it's flat as a board for the most part)
You beat me to the punch
2005
5.3
4L60E
35x12.50x17
3.42 (I know, Im one of the guys who was gonna ask this question)
16 mpg higway, 15 mpg on rolling hills, 14 mpg mixed hwy/city
No lift here, except a 2 in RC level kit. But I thought you may like a stock truck for reference.
Year: 2012
Engine: 5.3
Tranny: 6 speed
Tire Size: 265/70R17 (Factory tires)
Gear Ratio: 3.42
MPG avg: Highway average 19.6 @ 70mph, Mixed 25% hwy / 75% city average 16.5
4.8
4L60E
32x8x18
3.23
18.5mpg@70mph 14mpg@25mph
70% city15%hwy 5%towing
3.5inch lift and im in the central valley so flat
want to go up to at least 3.73 but what do you all think of 4.1? too much?
Stock reference for an LS.
2011
4.8L
4L60E 2WD
245/70/R17 (stock size)
3.23
19 Highway / 16 mixed / 14 city
Note- I live in a hilly area, I am constantly driving up and down hills around here.
Year: 2010
Engine: 5.3
Tranny: 6 speed
Tire Size: 275/65R18 Cooper Discoverer AT3's
Gear Ratio: 3.42
MPG avg: Highway average 18.5
Year: 2008
Engine: 6.0L Vortec Max
Tranny: 4 speed
Tire Size: LT265/70R17 Cooper Discoverer AT3's "E" rated
Gear Ratio: 3.73
MPG avg: Highway average 14
Don't do much in town driving with either truck.............My Cruze gets 38mpg highway back and forth to work, that's why trucks don't get much use. Wish my trucks would get that.
5.3
6-Speed
285/65/18
3.42
19MPG Highway/ 16MPG Mixed/ 14MPG City
Now we just need some of those big boys to chime in.
You rang?
2003
LQ4 6.0
4L80E
315-75-R16
4.10
Hand calc consistently says around 10.65 mpg with 70/30 highway/city with the cruise at 70 on the highway and sometimes "gettin' it" during the city commute.
    • So speaking of oil consumption with my L8T as I just changed the oil yesterday and made the switch over to Amsoil SS 0W-40 from the Mobil 1  5W-30 Truck and SUV I just dropped out. 2900 miles on that oil as well as  68 hours on that oil ( so used to equipment with an hour meter and that becomes valuable information to compare with others as well ). Once again the oil use was so very little, I am going to say it dropped under 1/16 of an inch on the dipstick. No towing was done and this interval was from early spring until now.    One interesting item to note is that going by the 5 quart jugs I was using before from Mobil, it was showing that I was putting in 8 US quarts to bring it to full if not slightly over the full mark according to their jug markings. Granted I did allow more drain time this time and in part because the engine oil was only lukewarm as I started it and let it idle and not for long enough to get the oil itself hot ( the engine was up to operating temp ). The oil in that state just seemed to take forever for it to drip out but not only at the drain plug but at the oil filter housing as well, perhaps I had never quite gotten all the oil out before and I could have still waited longer but as it was I waited well over 3 hours. I think next time if I have the time I will do an experiment by dropping the oil and lets say leave the pan under it for 15 minutes, then switch to another pail and let it drip out overnight and measure how much more oil comes out. So this time and yes I ended up getting it just over the full mark as I was experimenting with trying to get the level to the add mark after I had run it and then waited some and then added a bit and waited for a certain amount of time for it to settle to the add mark. I very well may not have waited long enough for that experiment but I got to the add mark, then dumped in a full quart and waited some and checked and then waited some more and it crept up more ... and then finally oops, it was slightly over full some hours later when it really had settled all it would. I find this engine sure takes time for the last bit of oil that gets poured in to finally make its way into the crank case. I can only guess at how much too much I added as per maybe a 1/10th of a quart. I had poured in 8.5 quarts going by the quart containers as per 8 quarts and 16 us ounces. I was shocked at how much this was off compared to the prior oil changes and if those larger jugs and they are not marked accurately enough or they contain slightly more than what they say, or the drain time factor made that much of a difference. But I know on this forum there have been others who have said they have put well over 8 quarts in their L8T and now I have also going by the Amsoil true quart containers. Its a confusing convoluted mess up here in Canada with some oil manufactures packaging is in true US quarts, some is also in true US quarts containers on an even number of quarts but also marked in liters which becomes the odd ball volume of a fractional amount of liters. Then there is the Liters only containers, no US markings as its a true metric container and only measured in Liters to an even number of Liters. But remember we used to have Imperial Gallons and Imperial quarts as well !.
    • Holy smokes. Clearly not a deal on that truck. I just mean in general, matte or painted trim is becoming more normative than chrome, but I know the Black Optics packages on various vehicles are being sold as uplevel trims. They look really good, but sheesh. It's just paint and plastic.
    • I Wouldn't Know Where to Begin    Oh I know where I would begin but I'm just one of over eight billion people on this rock. Eight billion versions of where the goal post is. How large it should be. How far to kick from. What ball is the right ball. Elevation. Age.....are you getting the point? It isn't about disagreeing with one individual. It's about agreeing only with one individual. One's self.   Agreement comes when multiple people hold the same point already. THAT is the goal of an education. Building the Social Contract. That thing that allows us to all read this sentence. We've agreed on the alphabet and how to arrange those letters into words we agree upon whose meanings hold true for everyone entering into that contract. Those words arranged into a sentence form an idea and several sentences strung together in a paragraph convey an argument for or against or inform the reader of a state, condition or perhaps reveal a things nature. Paint a word picture. Make oneself known.    This contract is not limited to words although they are often explained by words. Things like numbers and their usefulness. Physics, Chemistry, Medicine, Music, Art and so on.    The frequency of middle C (C4) is 261.63 Hz is a first principle. We build on that to make music we all can enjoy even if we all can not compose or play. You don't have to master it to make it enjoyable and useful.    So why is the Beginning so difficult? Why is agreement so elusive?   Everyone "Signs" the contract (when receiving that education in obtaining it)  but fewer and fewer in this world have any intention of living by that contract. They find exploiting that contract more advantageous. Disruption. With intent. Without intent. In Ignorance. In your face. With a double dog dare you. With a hold my beer. In resistance to that contract and in spite how it looks on us. It permeates the very air we breath.    In this way the contract is subject to advantage. Abide by it when it serves you, disregard it when it doesn't. Unpredictable and self-serving. Corrosive.....Toxic........   It says a lot about a persons character to disregard the contract, the truth, first principles. None of it good.        ********************************************************   https://medicine.yale.edu/news-article/character-vs-personality-who-we-are-and-who-we-aspire-to-be/   Just an interesting article.
    • It costs $5,250 for the Yukon Nightfall option (black wheels, emblems and illuminated black GMC grill badge). What a "deal".
    • I keep getting the above error message on my 25 Sierra.  If I reset the infotainment unit (via the phone hang up button) it will work again for a day or 2.   But I dont want to do have to reset  all the time. Works fine in my 2023 Corvette. On both vehicles I connect wirelessly.   I have a Google Pixel 10 Pro XL, phone is up to date.  Any Ideas.  See attached
