Stabilizer Bar add on to my 1500 Sierra ext. cab. Can I???
New Rams, Fords, etc. all have a sway bar under the back axle. Tahoe/Yukons do as well but why not the 1/2 ton pickups? I think my wife's 2007 Dakota quad cab does as well. Can I put one on my 2006 Sierra 1500 from a Tahoe/Yukon? Maybe the axle on the SUVs are more narrow than the pickups? I would like less roll around the corners and in the hills. Thanks
I've used Hellwig and Hotchkis.
Upgrade the front bar and add a rear. It will make it corner night/day from now.
Only downside is if you drive over a lot of super rutted roads, you lose some articulation in the suspension (more for the crazy off road types though).
Thanks for the replies. I don't plan on off roading any; she's more of a street truck so I will look into the front bar too. Thanks
Do them as a matched pair. The OEM is hollow, and has a lot more flex than say the Hellwig. Matching the front/rears with aftermarket will give you a lot better handling (my '00 with Hellwigs would handle as good as my Acura CL!)
Great! Good to know what I can expect with the sway bars. Thanks
Hollow anti-roll bars are actually the better design. There is a good read on how that is at http://www.hotchkis.net/_uploaded_files/hollow_vs_solidinstructions162file.pdf. The most important thing about swapping anti-roll bars is to make sure the front and rear bar are matched. The bars cannot just be stuck on, you need to be aware of the bars properties and make sure the compliment each other. Otherwise you will end up will an ill-handling vehicle. You don't need to be as precise as NASCAR, but you do need to be aware of what the changes will do.
Don't forget that there are also airbags, and other spring options. Each have there plus and minus.
I don't think it will make your truck ride rougher. Its just for handling. I drive many old cars with stabilizer bars (from the late 60's) and they ride nice. Just helps with cornering a higher speeds. I do think it will keep your truck from 'flexing' to its max but not a rough road.
What the sawy bar is going to do is prevent one wheel from moving too far compared to the other. Under normal driving, you don't really notice it. In the city, you may notice it when driving over speed bumps diagonally.
Personally, the plus' substantially out weigh the minus'.
About the hollow bar, I meant the OEM is "more" hollow (ie thinner walls). I'm super pleased with them on my GMT900 as well as on my GMT800.
I know what the bar does, I was just wondering if it would cause the axle to not articulate enough side to side that it would be rougher on washboards. I like the idea of it for towing and cornering, but I don't wanna lose too much traction on my low wheel in bendy situations.
    • You could try a used 1, they used that engine in the Astro vans, Plenty of them in the boneyard. Look for a wrecked or rotted 1 so the chance that it was scrapped for that reason and not a mechanical issue will be greater
    • Google converting 98 4.3 spider injection to carburetor if all else fails.
    • That computer lies!
    • My centre console USB ports haven’t been working and the one in the glovebox is starting to act up. When I plug my phone into the cord the radio will go black and stop playing, and the CarPlay is inconsistent.   I checked the fuses and they were fine. I changed the USB port out and still nothing. Hoping for some advice on what I should be looking at.
    • The truck is a 1995 Chevrolet S10 Blazer, 4.3 VIN "W" engine. :cracks knuckles:   On a whim - because I needed a headache - this truck was for sale so I stopped to take a look. Doesn't run. Well, it does, but barely. Long crank, choppy idle, bad misfire(s), it REEKS of fuel. I can DO this..I'm thinking. Diamond in the rough. One owner until last year. A young guy is selling it, he bought it 6 months ago. It stranded him more than once, he's got a newborn. It was in the shop 10 days ago and he "thinks" they said it needs a new fuel injection system. He can't put any more money into it, needs it gone. I was thinking of upgrading my Macbook, which is a total want, not a need. For less than the price of a new laptop I can have fun for months tinkering on this truck and enjoying it. I'm taking this truck home. The guy was beyond thrilled, his wife was there, she thanked me profusely, I could tell they were hurting. They seemed like good people in a bind.   Some parts, a wash, maybe a set of tires, and I can have a few months of fun and then turn it for beer money (or the next project).   Sure enough, there's a work order from a shop last week in the INCHES of paperwork on this truck dating back to when the first owner bought it. They put a new distributor in it, fuel injection work describes basically opening the plenum and putting it back together. He said he couldn't afford any more work so he had them button it up and that's when he put it up for sale.   I'm not well versed in 4.3. I did discover 1995 uses the 1992-1995 SCPI "Spider" injector which is riddled with issues from splitting lines, clogged or cracked poppet valves and plastic spider legs that crumble over time. Cool. I'll just order me a ne---. Oh, the auto parts store doesn't have it? Rock Auto doesn't have it. eBay? $$$$$$ for used. These are UNAVAILABLE period end of story unless you know "a guy" who's still got one in a box somewhere.   Can't upgrade to the '96-'04 injector, it's a different plenum, wiring/pinout and sensor config.   There are a few kinda "know a guy" -guy rebuild services for these injectors out there for about $350. Okay, Okay... I'd like to know if anyone has used them? Anyone got a lead on these crappy 92-95 spiders?   I also don't want to send MY spider to Narnia and back without knowing if that's truly the problem. I guess I'll need to pull apart the plenum and do some digging.   I was also thrown for a loop. This 1995 model year truck has an OBD-II connector. The interface is decidedly not OBD-II. I can read and reset trouble codes and view live data, but there's not a lot of data. Like misfire count and on what cylinder, that's not there. It's OBD-1.5.   Nothing is ever easy. Now it makes sense why this guy wanted to disappear this thing for cheap. I'm guessing the shop told him the injector is toast, the part is unobtainable and they're not going to sort sending the thing to a rando offering rebuild service on craigslist, and the kid likely can't be without a working car for 3 weeks even if they'd facilitate that.   Experience with these early SCPI's? Stories? Things to check? Sympathy? (..Nah...)   This can sit until I sort it. But I haven't had a problem with a vehicle I couldn't easily solve in a long time.
