Heater blowing smoke
SarahsGMC
Friend made the mistake of tacking some welds on the truck without unhooking battery a few hours later we crankd the heat and smoke was rolling out of passenger footwell. Now the fans won't go off unless I unhook battery. Any idea on what happened? I'm convinced it has something to do with welding but not sure.
To the bar we were making only reason I say that is because the guys that did my bros exhaust fried my brothers o2 sensors but I did some research and found the 03-06 heaters wiring harnesses are being recalled..
It is a very common issue. The fix for it will depend on if he has the auto climate control or manual1-5 fan speed .
Auto = buy the part on amazon and do it himself
Manual= take truck to dealer, they will grandfather him in and do the repair for free.
I'll try and find my post from back in the day.
You will find the resistor block that controls fan speed has burnt out, and it may have taken the plug out as well. You will likely only need the resistor block itself, and the connector that plugs into it. I would think that GM or some aftermarket company will have a repair kit to replace those two parts. It is very common issue.
Yea we tore it apart today and found out its real common I have the relay just need to get the plug
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
