Best place to buy a rebuilt 5.3L
I sold my S10 and bought this back in April... Don't think I'll be buying anything else for quite some time, which is why I'm so pissed at my truck. No matter what I do, it's going to be very expensive, and likely a big pain in the ass, but still cheaper than a "new to me" truck...
155898d1337480505-pics-my-new-me-65-289-coupe-150705_10100469808272378_12712028_47542262_1037749531_n.jpg
With my research, I can buy a stripped down rebuilt long block from advance/autozone/similar for around 2 grand but doesn't have a timing cover, oil pan, etc like most "typical" long blocks. Other places sell a more "complete" longblock where you just bolt the front accessories, intake, etc to it and you're done, but they're typically $800 more... I don't want a junkyard motor, I bought this truck with 60K on it, and who knows what the hell was done to it before I got it... they may have changed the oil every 10.000 miles, same for any junkyard motor. There's too much work involved for the little bit of savings a motor with 50-75K+ miles will save me.
So I have an update. After being sick, I finally got the truck back together. I also had to order an in-lb tq wrench. Nobody carries one in stock (that was reasonably priced) that has Tq ratings that low, (22 in-lbs) it's barely even hand tight...
Anyway, I watched this video on youtube about cleaning the lifters. I removed the DS rockers and rods to check for bent rods, all looked straight and clean with little wear. I then sprayed B12 into the rods down into the lifters, put it all back together and ran an engine flush.
Not 100% but WAAAAAAAAAAAAAY quieter. As in, zero noise at idle, and none or very quiet under light to moderate throttle. Even under heavier throttle it's pretty quiet. To best describe it, it sounded like a bad ticking exhaust leak inside the cab, now I can barely hear it. SO. I'm going to keep running marvel mystery oil in it and do another valve cover removal/cleaning in a few months, next time to include the PS, although the noise seems to be limited to cyls 1 & 3, you never know and do another engine flush.... then since there's no codes, the truck runs great, I don't see any wear in the valve train and no particles in my oil... I'm going to just drive it until it blows, which may take a really long time, especially considering I only put about 5K/yr on the truck the past few years (was about 15-20K when I first got it!)
Thanks all for listening.
    • Thrust bearing is a very small window.  But nice try.   Turbo oil filter?  Haven't seen any failures.  Change your oil more frequently.  Use a better oil than the factory oil.
    • There is a p/n called out in the one PI that GM has.  Curt 57003 inline load adapter that is used for LED trailers that are having trouble with these newer trucks.  No cutting, no splicing, etc.  GM did update the lighting module around 2023 to better pick up trailers with LED lighting, but it still can happen.     Here's the link to the Curt site for it - 7-Way RV Blade LED Electrical Adapter (Not a Wiring Extension) SKU #57003 by CURT   The PI I am referencing - MC-10208985-9999.pdf   Its not just a GM deal either.  Newer Fords and Rams have this same problem.       In another PI, they recommend that the trailer has a Pollock brand 7 way on it as that is who makes the truck sides for the OEMs.  GM is also big on making sure the trailer is trouble free.  So no wiring issues, all lights are functional, better quality 7 way plug, etc.     The other PI I am referencing - MC-10178359-9999.pdf   The model year range is older but it is the current PI for 2014-2026.  It calls out the Pollock RV HD 7 way they recommend.
    • That's part of the problem...the EGR has already been replaced, and I've already had the complete intake assembly removed, and the EGR passages were clear at that time. That leaves wiring, PCM, or another variable that I wasn't expecting. Best I can tell, it's not wiring or the PCM, so I'm grasping for straws.   The PCM uses the MAP reading to confirm the requisite loss of vacuum in the manifold when the EGR activates. Since that's vacuum related, it involves a lot of other systems which could play a role.   The overall diagnosis has to be considered too. The fuel lines in the intake had rubbed through and were dumping fuel into the intake, drowning the cylinders in fuel, and putting raw fuel into the sump and cat converter. The fuel system has been fixed but the complete path of damage may not be. If the cat was damaged and melted the internals, it could be partially obstructed and also playing into the EGR issue.   I'm retracing my steps; trying to go back to thinking thinking Horses not Zebras based on the clues I've been given. These engines aren't *that* complex.   Could it be, now that the truck is running well, that carbon and crud from being run with the fuel system in disarray is now dislodging and clogged my clean EGR passages where I can't see?  That's what the code is actually saying. The flow is restricted, dummy. Retrace step 1.   I may just need to remove the lower intake again. Before I do that I'm going to try removing the EGR and running the engine for a few seconds to see if it will blow anything lodged in the egr passages out through the open ports.     That's been helpful in the past. For the spider injector, there's no guarantee I'll get a working one. The spider I have seems fine now that the high pressure fuel line isn't making an early delivery via large hole. SO at least I'm not marooned and looking for one of those.   Row52 (dot com) is also a good one for watching for vehicles at local yards.
    • Disassembly may be Required!   Every blender makes claims but do  you ponder those claims? What was really said? Was it true?  Motive for saying it? What does in infer?  Is that inference true?    Let's do one.    Claim: Made from shear stable base oils.    What was said: Base Oils are shear proof.   Was it true: Yes.  ALL base oils are Newtonian.    Motive / Inference: To imply the fully formulated product is Shear Proof.    Is the Inference true?: Most fully formulated multigrade oils contain Viscosity Modifiers or VM's, sometimes called VII or Viscosity Index Improvers. There are four types. One is in fact shear proof but it also has a bad effect on extreme cold flow and is restricted to use in specialty oils. A second has limited shear called a 0-5 SSI polymer. Meaning its shear is limited to a range of zero to five percent as reported by the ASTM D6278 Shear Stability Index test. A few high end oils, like Torco SR-5, use them and brag about it profusely. Actually all that use it point it out. The last two shear dramatically and are often marketed as a 'feature' of the product aiding the oil to meet fuel standard requirements of ever stricter rules. One shears more than 5% and the other up to 20%. As you make guess, cost is directly linked to shear down and as such the majority of oils use the cheapest organic polymers sold to make grade and pass stringent tests.    PPD's or Pour Point Depressants also shear a bit, only a few percent and hide inside the 0-5 SSI capabilities.    The blender knows he can not out engineer Stribeck. Physics is not a suggestion. But he can wordcraft the unsuspecting toward believing a false claims INFERENCE. This is LEGAL. It is COMMON, and it is EFFECTIVE.
    • I don't recall ever dealing with one on an '06 and back. It may not even exist on that. I can't remember for sure.   Any kind of ice in or after the evaporator is normally due to low charge with both a clutch-cycling orifice tube system, and a TXV system.
