Engine oil consumption - Toyota
RyanbabZ71
Doing the first oil change in our van and ran across this page. 1.1 qts per 600 miles max.
Ryan
Talk about CYA!! Hope your van's not using that, or any, amount of oil!
That's almost as much as the 350 in my 1990 was burning before it blew. Seems like a lot?!
The part about oil being "diluted", since when does oil get diluted? I would be worried if there was more than I put in.
Coolant dilutes oil quite well, as does raw gasoline. See what I mean by "CYA"?
no not using any. Only have 6500 miles.
Just posted it because of all the gm truck engine oil complaints (see the light duty area. (example trucks burning 1 qt of oil per 3K miles)
GM is the same. Unless you are using over 1 quart per 1000 miles, they don't consider it excessive in the book.
All vehicles use some oil. Most use so little that it's almost impossible to tell between changes. I'd be seriously upset if mine used over a quart between changes... much less a quart every 600 miles!
GM is 1 qt per 2000. Toyota has previously been 1 qt per 1000, so the 600 is new. Did GM change recently?
Wow. Just think Ryan, you could be about 100 miles away from adding quart number twelve and still have it be considered "normal" consumption in toyota's eyes. "Uh, yes, I'm here because my six month old minivan(Sienna?) is using a lot of oil and I think something is wrong." "I'm sorry to hear that Mr. Smith. How many miles does your van have on it?" "Right now it's got about 6700 miles on it." "And how much oil have you added?" "Three GALLONS." "Oh, that's normal."
According to my GM service manager (and friend) they won't pursue a warranty claim on anything less than 1 quart per 1000 miles. I'm only going on what he says.
I would imagine it may be different by vehicle and motor. I'd bet the 8.1L had a pretty high "acceptable" rate. I had to search, 'cause it's been a while, but found GM bulletin 01-06-01-011F (Jan 13, 2009). There may be a newer one (?).
Subject: Information on Engine Oil Consumption Guidelines
Models: 2009 and Prior GM Passenger Cars and Gasoline-Powered Light Duty Trucks Under 8500 LB GVW (Including Saturn)
2009 and Prior HUMMER H2, H3
2009 and Prior Saab 9-7X
Oil Consumption
The accepted rate of oil consumption for engines used in the vehicles referenced is 0.946 liter (1 qt) in 3200 km (2000 mi).
Important: This rate only applies to personal use vehicles, under warranty, that are driven in a non-aggressive manner and maintained in accordance with the appropriate maintenance schedule, with less than 58,000 km (36,000 mi), or driven at legal speeds in an unloaded (for trucks) condition.
Found the TSB posted here, but that doesn't mean it's right.
That sucks, hope you don't have that problem ever. My truck's oil consumption slowed down drastically following my last oil change. At 2k miles into the cycle and only down 1/2 quart.
My 4.8 burned a quart to quart and a half per oil change. So 7-10,000 miles
Sent from my DROID RAZR using Xparent Red Tapatalk 2
