Need opinions on which rim!
Blackout18
Alright guys time to be the judge, Lets get some opinions on which you think would look the best on my black silverado 1500. Keep in mind it will be lifted 7.5 inches, wrapped in 35 inch toyo open country mts. Trying to go with a blacked out look but let me know which one you think. I need some opinions!!
Rim 3-Rim 2-Rim 1
+1
Or get something chrome or silver and plasti dip 'em. Easy to fix off road rash that way and if you get bored you can change the look when you feel like it...
1st-Rim #3, 2nd-Rim #1, 3rd-Rim #2
I agree. For me, it's pretty close between rim1 and rim3...but rim2 is a distant 3rd...I'm not a fan of the rockstars. Just my opinion.
I dont like the first ones, they look too much like those dick cepek rims that everyone has. Rockstars are cool, but everyone has them too. so my vote goes, #3,#2,#1.
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 252 Guests (See full list)
