2011 transmission fluid and filter change
Going to change the transmission fluid and filter on my 2011 5.3 auto z-71 1500. Does the pan drop and come out when I take the bolts out. Just from a quick look at it nothing seems to be in the way except for maybe the exhaust pipe. I just want to make sure before I start taking the pan bolts out that I don't run into something unexpected. I remember my '01 was a pain with the shift bracket in the way. lol
you may have to remove or bend shifter cable bracket, then put jack under transmission, then remove 2 mount bolts, else you may damage shif solenoids in transmission.
don't force the pan in or out
The shift bracket isn't a problem on this truck. Its just tight clearance between the exhaust pipe and the pan. I moved the pan around for a while and finally got it out. The truck has about 11,000 miles on it. I tow and haul a lot and wanted to see how everything looked inside the pan. The magnet had a fair amount of metal fuzz on it but otherwise looked fine.
I put Amosil Dex VI in it and replaced the filter. It feels like it shifts smoother.
For others that may read this thread, be very careful when removing the pan. You can easily break a couple of solenoids/wires by "moving it around" if clearance is tight. Best to loosen the the tail-shaft mount and raise the rear of the trans slightly to obtain the clearance or lower the exhaust. Your choice.
Btw, it's Amsoil synthetic, not Amsoil Dex VI
I serviced my tranny at about 12k, no big deal, your truck, your money! If it helps you sleep at night then more power to you!
Nothing wrong with early servicing. Lets you know how things are going if you do a bunch of towing/hauling.
AMSOIL Synthetic (ATL) in my trans since about 5,000 miles, now 10,700 miles. Complete fluid replacement as well as every other lubricant changed over. I noticed a diffinite improvement in trans operation since. Trans shifts much soother in cold weather. No trans complaints like others have with the 6sp, mine is flawless.
im an old guy and know transmissions pretty good and doing a service this early is a complete waste of money .....100% waste of money .
not knowing how things works and paranoia leads to this exact thing of over doing things ...
my opinion only,,do not freak out me , i hope you understand what i mean,all of you ,not just the OP
Not in my opinion is it a waste of money. I know how much better my truck and car perform with 100% synthetic lubricants in it over the cheap factory bulk supplied minimum spec'd lubes.
In the long run 100% synthetic lubricants last longer than other lubricants do, which reduces lubricant costs and the amount of used oil that must be disposed of.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
