Chit chat
SarahsGMC
Snowing here, lol. I'll take it over nothing.
Wow, and I thought we had a long winter here.
  • Replies 9.5k
I wish I had a winter
I don't mind the cold so much as I do the snow. I would be happy with 60 - 80 degree temperatures all year round with no humidity, but that will never happen.
Now that I can't use my garage anymore the weather really irritates me
Sent from your truck via Tapatalk
Ordered new tires for the truck. Cooper AT3s in 275/65/18. Go on Saturday.
It was tire gettin season in like December for me but I didn't have the money. Gonna be just shy of a grand because 18" wheels are stupid. :lol:
I get 2-3 months of a mild 50-40 degree winter. Barely any rain. I get 7 months over 85 degrees. I want winter
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
The only weather I hate is rain, and that's because I work outside, although lately I've been lucking out and get inside/shop jobs when its raining at work.
Winter? Snow? No humidity? What are these things you speak of? Let's just all go fishing and catch some fishies!
River was down too low to easily launch the boat. Oh and it was 45F and windy, not to mention the snow.
My truck is making screeching sounds in the front somewhere
    • Thanks everyone for the help!   I'm going to stop into the scales one of these days and weigh my axels, for the time being, I am going to run Toyo's recommendations and also do a chalk test. I have a tire shop that's going to try their scanner to reprogram and set the the factory psi values lower, and if they can't I'm going to order a scanner and do it myself!
    • You won’t do better than stock exhaust without headers. Just put your favorite muffler on it and it will do the job.
    • I have seen different people in different places post different sizes of exhaust as stock for my 2014 Sierra L83. Some say 2.5 some say 2.75. I am considering replacing the muffler with a Dynomax Super Turbo, perhaps 17739.  I had the factory L83 5.3 replaced with another L83 5.3 from Jasper Engines. I also put new Walker Cat / Y pipe on. I would appreciate opinions suggestions about what would be a good muffler setup. My main interest is a low rumble and the best flow / fuel mileage I can get. Not interested in straight through glass packs or loud exhaust. Those days are way behind me now.  Thanks Guys.
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"     I'd say its the head, and its either leaking at the casting line and dripping down the intake into the cylinder, or its another spot on the casting itself at the cylinder that is getting wet.
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
