Chit chat
SarahsGMC
I have a bunch of different playlists I use. I don't think I've ever listened to the radio on this head unit
Sent from the side of the road...
  • Replies 9.5k
Something about the appearance of my truck I'm not liking. I think it's these big oversized GM vent visors... Opinions, I'm thinking they gotta go. 3u8eputy.jpgy8ehaba8.jpg
Sent from my iPhone 5 using Tapatalk
I don't mind the front but I've never seen the point of having them in the rear too. You could get some lower profile ones.
Wanted low profile inchannel ones but I got these as a gift and at the time GM didn't have the inchannels. Only these things.
I believe she also started the "What did you do to your truck/ shop today?" thread which is by far the largest thread I've ever seen
Sent while drinkin' a cold one...
I got thread makin skillz :P lol just kidding but yea these really took off I made this one so people could discuss whatever without cluttering the lounge and seems to have worked.
Sent from the toilet
Was two excellent ideas. This studying for promotion to lieutenant is killing me!!!
Thinking of installing, well, a bunch of stuff. But cab lights in particular this time! lol
Im torn between the stock 07.5+ smoked LED ones (with three LED's in the middle bar) and the direct replacement Recon makes with 6 LED's in the middle. The price difference for the new stock-style is more than double, but I think they are a cleaner look. They both are plug and play with the factory 02-early 07 harness (just need to reverse polarities for the LED's) just don't know which look better to me, or what would look better on my truck. Been clicking back a forth between two tabs looking at pictures for 5 minutes now trying to determine which looks better, and am I willing to pay that much for stock cab lights
I'm not a fan of cab lights. I think a few in the grille look good. Also thought about putting the super bright LEDs under the tailgate. But I've had a less is more mentality lately.
I think it would be a bonus for if/ when I get that paint job mentioned in the other thread
