Leaks
99 Silverado Z71 w/ 5.3, I bought it back in May and knew I had a leak from the driver side front axle seal.
Recently I have been noticing a second spot underneath on the driveway. Got under neath and see the rear bottom of the engine coated in oil.
Closer look shows what looks like a leak from the oil filter adapter plate? Was surprised I didnt have the oil cooler lines.
While under the front it looked like the power steering pump or lines were leaking. Took off the plastic plate under the front and saw this:
And this:
Water pump starting to go?
So my questions are:
Is that the oil filter adapter leaking and is the repair just the O rings?
Is it the power steering pump leaking or maybe just a seal? How big of a job is that?
How difficult is the water pump?
I am fairly mechanically inclined and enjoy fixing stuff especially on vehicles. However some things arent worth the time/effort. Thanks for any assistance/info.
alldata,get that,
p/s seals are easy to me ,
water pump has failed
gasket for cooler line adaptor not oring ,see a parts counter
your truck is a leak box lol
On the driver side front axle seal, when you do it be sure to check the gear case vent directly above the axle. The is a large plastic piece that screws into the differential where vent hose goes on. It has a place for a socket, make sure it is snug. They sometimes loosen and the leak looks like it is from the axle seal.
Could be the axle vent but that looks like the seal and it's common. Just don't end up like me paying a shop to do it and now magically after they did some warranty work because it was leaking again lose a bearing in the front diff........ this is what I get for not doing wanting to do something myself. The only crappy thing is if the 8.25" is like the 9.25" where the drivers side stub shaft sticks in the side requiring you to split the diff and pound it out breaking the spring clip that holds it in place. That might just be a 9.25" problem though.
Waterpump is about the easiest thing ever. It might just be the gaskets to the block but being a 99 just change the pump out. Once you get the shroud and clutch fan off it's only your tensioner pulley and 6 bolts plus your hoses...... Simple. I use my tool to pull the grinding disc on my makita grinder to hold the water pump pulley and just a 24" crecent wrench. They come off like nothing like that. Generally even holding the belt tensioner to add tension the belt will not hold it to break the fan loose.
PS pump seal isn't bad either so just buy the puller. I tried switching pumps on mine and after 3 "new" ones that howled like a roots blower I put a front seal on my original.
Looks like the oil cooler gasket to the block.....2 bolts and it's done.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
