electrical problem 02 silverado
So i took off the metal cover z71 logo on the brake light on the back of the cab to paint it.i lost the screws and put random screws i had laying around from my house "dont know if this was the problem but doubt it" around that same time blinkers and brake lights are acting funny
1.blinkers in dash stay on when i brake
2.when using blinkers during the day and press brake the blinker im using flashes faster than normal
3.all the back lights flash kinda dimly when brake is pressed when atleast in parked havnt checked if they do it when driving
Has anyone had a similar problem or an idea what wrong
i havent messed with anything else but that cover plate
Thats what i thought but i checked every wire and have had the cover plate and screws out for awhile
all i know is im stumbed lol
Good luck welcome to the electrical nightmare. Time to pull out a multimeter and get a friend, you have a long process of diagnoses to do if you tackle this yourself. Let us know what the problem is if you find it.
Best get a schematic.
Sent from my Nokia 5190 using Tapatalk 2
Hahaha always afraid of hearing that question when my trucks and cars have an electrical probelm.
Yes when i figure it out i will let you guys know
so far you guys on here have been really helpful and i appreciate it
Sounds like you may have more than one problem, could be a bulb is blown (or just not making proper contact) and/or you have a ground issue somewhere. Hope you can find the problem quickly.
I'm not saying this is your problem but once I had both filiments of a 1157 bulb fuse together tying marker/taillight and brakelight/signal circuits together causing crazy combinations of blinking lights inside and outside. Good luck with your search
What do you mean filiments fuse together amd what did you do to fix the problem
Just what it sounds like, the filiments inside the bulb comes into contact with each other and get stuck, linking both circuits. The fix would be to replace the bulb and be sure there is no damage in the socket.
this..common issue
Oh ok thanks ive replaced some bulbs but not all of them ill try replacing all bulbs as far as connectors what do i look for to tell if they are messed up
Burning or corrosion
I'd look for anything that is melted, burned or corroded. Those would be the suspect areas to inspect more closely to be sure they are still making contact properly. Also make sure all the sockets are dry, on my truck I have one day time running light fixture that keeps getting flooded out and have to drain it from time to time.
