Color match or no? Opinions wanted...
Alright guys the mod bug is still hitting me hard. What's yalls input on color matching the grille and bumpers? I'm planning on getting the whole thing repainted in the next few years anyway so if I do a terrible job no harm no foul :lol: done the frame, mirrors, and valence so far. Still planning on wheels eventually. If someone could photoshop the rest of the front blacked out for me that'd be very helpful. This is what I've done so far:
Sent from my SGH-I927 using Tapatalk 2
That'll look great! I'm keeping the gmc black with chrome outline
I have a little thing. I like color matching most of it. I still prefer chrome wheels and bumpers
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
That's another option I was considering. Doing the grille and leaving bumpers and wheels. I just don't know. I don't want my truck begging for attention but I want it set apart from the rest if that makes sense
The look of the original SLT All Terrains is my favorite. Everything is color matched except bumpers and wheels. And the grille but is rather that be matched.
I think I'm gonna go ahead and spray the grille tomorrow and see how that looks
Colormatch the grille. Leave chrome grille surround
I just woke up so I may be having an idiot moment... ur talking leave the chrome alone and do the flat faded black in the middle?
I'm normally a fan of color matching.. but i think your truck looks good the way it is. Just start with that body lift you were talking about! That should get the bug off your shoulder for a week or so haha
Thank ya I did the zone 1.5"
Hey Zack, while my truck is a late model, i did color key it. when i bought it, only the front grille and rear bumper were chrome so i sprayed both, while wheels are black, they have a 1/4 inch bead thats silver. i left the emblems their natural colors as well as plastics that are flat to provide just a little contrast, as all black doesn't appeal to me. check out my album as i have a picture in there of when i got the truck and how it looked. good luck !
Man that's a sharp truck! Nice work!
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
