Anyone have access to GM document #PIT5166C
The radio in my 2012 Silverado emits a loud, annoying and constant high pitched noise, even when shut off. Apparently, GM acknowledged the issue and said it was due to a cooling fan in the radio. They outlined this in PIT5166A and PIT5166B. However, they said the issue was normal and to not replace the radio, and that GM was working on a fix. I read on another forum that GM came out with a revised notice, PIT5166C, but I can't find reference to it anywhere. I was wondering if anyone has access to PIT5166C and if so, does it authorize a repair or radio replacement? I know I could probably call the dealer, I just want to do a little research to see if its worth my time to take the truck in. Thanks
#PIT5166C: High Pitch Sound From Radio Display - (Jan 4, 2013)
Subject: High Pitch Sound From Radio Display
Models: 2012 Buick Enclave
2012 Chevrolet Malibu
2012-2013 Chevrolet Avalanche, Silverado, Suburban, Tahoe, Traverse
2012 GMC Acadia
2012-2013 GMC Sierra, Yukon
Equipped with AM/FM/CD Radio (RPO US8 or UUI)
This PI was superseded to update recommended field. Please discard PIT5166B.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern
Customers may comment about a high pitch buzz, whine, squeal, or hum noise from the radio display. This condition is most noticeable when the volume is very low or off.
Recommendation/Instructions
Replace the radio to correct this concern.
Please contact your local ESC to obtain a replacement radio that does not exhibit this concern.<a href="http://gsi.xw.gm.com/newsi/showDoc.do?docSyskey=3251398&from=bcpi#N65597">
Warranty Information
For vehicles repaired under warranty use:
Labor Operation
Description
Labor Time
R0760
Radio Replacement
Use Published Labor Operation Time
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
I'll have to check mine. Is it the nav or Bose or six disc?
It is not nav or bose, just regular CD. Start your truck, turn the volume down, if you have it you'll hear it. It's a distinctive buzz/hum from the radio deck.
2012 GMC Acadia
Condition/Concern
Labor Operation
Description
Labor Time
R0760
Radio Replacement
Rob, I appreciate the help, thanks. So it looks like they are replacing the radios now. Thanks again
  • 1 month later...
I just took ownership of a new 2013 Sierra SLE about two weeks ago......it has the standard factory radio/speakers.
I too have noticed the high pitch noise....which led me to google....and that led me to this topic/forum.
Is it safe to say there is a definate fix via replacing the radio? I have yet to call my dealer but want to have my research done before I do.
Any further insights would be appreciated. Thx, John
I just dropped my 2012 GMC SIerra off this am for this & a couple other concerns. My truck has the "UUI" radio head unit. I'll let you guys know how it turns out...
I picked up my 2012 Sierra yesterday evening. That annoying buzz noise is gone, the new replacement radio head cured it. :thumbs:
Does this apply to the Bose system too? My '12 Sierra does it, but it seems to vary in pitch with the throttle, or get higher pitch as engine rpm increases. Maybe not the same issue but definitely a noticeable whine.
Not sure what you mean "radio head"?
The radio itself, sometimes called a head unit.
    iso221
    iso221
  • Who's Online   6 Members, 0 Anonymous, 586 Guests (See full list)
